| » wsnider4853 |
Model Number: FGF326ASJ Brand: Frigidaire Age: 5 - 10 years
The oven and the broiler will not heat. The oven light works fine. The stove top gas burners work fine. The oven and broiler temp control (electronic) seems to work fine. When I select a temp. I hear a click as though the oven or broiler is attempting to engage but it does not heat. I do not smell any gas coming from the oven or broiler.
Any suggestions would be much appreciated. Respectfully, wsnider4853 Ads By Google Related Models |
Hi.
Remove the bottom and flame spreader inside the oven to get to the ignitor. Set the oven to BAKE. Check at the disconnect plug if there is 120VAC going to the ignitor. If there is proper voltage or the ignitor is glowing - replace the ignitor Part number: 5303935066 Here are the breakdown diagrams and Burner parts for Frigidaire FGF326ASJ - AppliancePartsPros.com Please, post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I have power but gthe ignitor is not glowing. Do you believe that the ignitor needs to be replaced. Also there is no gas, is there a safety feature that turns off the gas when the ignitor is bad?
Quote:
If you are getting 120VAC at the ignitor's disconnect plug and ignitor is not glowing - replace the ignitor. (As I've mentioned in the post above).
Simon.
__________________
| Display Modes | |
