Discuss
replace oven circuit board?
 in
Rewired outlet, heard pop and oven timer stopped working, so unplugged and turned breaker off. When I plugged it back
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replace oven circuit board?
  #1 (permalink)
Old 01-16-2013, 05:45 AM
Junior Member
gjmiller is on a distinguished road
Default replace oven circuit board?
Brand: Frigidaire   Age: Less than 1 year
Rewired outlet, heard pop and oven timer stopped working, so unplugged and turned breaker off. When I plugged it back in to another outlet, the stove top works, but no timer, clock, or oven control.
I'm guessing there's likely no fuse, so wanting to know how to get to and replace the circuit board.
Any advice would be appreciated.
TIA, Gregg
Ads By Google
  #2 (permalink)
Old 01-16-2013, 04:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Gregg,
In order to provide most accurate advice we need the complete model number of the range.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-16-2013, 05:17 PM
Junior Member
Default
Thanks for the response, the model of my Frigidaire oven is FGF348KSK and serial # is VF23442274
gjm
  #4 (permalink)
Old 01-17-2013, 12:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Gregg,
You are right - there's no fuse in this range. The correction is to replace the oven control board. You also may want to order the overlay because it's adhered to the control board. In order to replace it just pull the range out of the wall and remove the control panel rear cover. The control board is secured with 4 screws. Do not forget to unplug the range first.
- The control board Part number: 316455410
- The overlay Part number: 316220700
__________________
  #5 (permalink)
Old 01-17-2013, 01:24 PM
Junior Member
Default
Thanks Gene, that's exactly what I needed, and I certainly wouldn't have known that I needed the overlay, so thanks for that too. Didn't figure it would be particularly difficult, and something I should be able to do myself.
You have been a big help,
Gregg
  #6 (permalink)
Old 01-17-2013, 03:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Gregg. Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace circuit board and test components in my Maytag stove APPSusanp Oven Repair (including Ranges and Cooktops) 3 11-02-2009 03:09 PM
install circuit board ge oven arne Refrigerator & Freezer Repair 0 09-19-2009 10:07 AM
how do i replace a relay and circuit board slgant@verizon.net Dryer Repair 0 08-21-2009 08:10 PM
circuit board replace jazzdeck Oven Repair (including Ranges and Cooktops) 1 05-02-2009 03:15 PM
oven circuit board trouble nancyl Oven Repair (including Ranges and Cooktops) 1 03-24-2009 11:26 AM
