hawkeye1315
#1 Posted : Wednesday, September 30, 2009 6:44:15 AM(UTC)
hawkeye1315
Done a lot of reading on this board, problem is still not resolved. Whirlpool Model #GJP84902, oven bake element stopped working. Removed original element, found pitted, measured no resistance. Replaced with new element, resistance measured (can't quite remember value, but it was either 28 Ohms or 40 Ohms I think). With oven on, past pre-heat (broiler element is OK), measured voltage between each terminal and ground = 100 V-AC. Voltage between the 2 terminals however, measured 0 V. Can't find a breaker/fuse on wiring diagram for bake element, only found for 2 electrical outlets. Not sure what to do next, is it the relay? If it is the relay, can someone post a picture of it?
Thanks in advance.
Monterro
#2 Posted : Tuesday, November 10, 2009 5:46:57 PM(UTC)
Monterro
Thanks in advance.
I have the same issue. Have you figured it out yet???
#3 Posted : Wednesday, November 11, 2009 5:20:31 AM(UTC)
Replacement parts for WHIRLPOOL GJP84902 | AppliancePartsPros.com
I could not find any tech info on this unit.
Replaced with new element, resistance measured.
Usually if they have continuity they are OK. Though a 40 ohm reading would be a 1440 watt element which seems low.
Could have been just ghost voltage but 100 volts does seem high for a ghost.
The bake relay is probably on the control board. The black boxes are the relays. You have to replace the board as the relays are not readilly available.
I would check the thermostat just in case but this is a long shot.
Here is a good link.
http://www.applianceaid.com/elecrange.html
Check out 7, 8 and 21
Hopefully someone with more info on this unit will jump in and help!!
Monterro
#4 Posted : Tuesday, December 22, 2009 12:50:12 PM(UTC)
Monterro
Originally Posted by: denman Go to Quoted Post
I Have replaced the broken lower element also and still found an issue on the timer board. It looks like a short on the back of the P2-4 terminal. Which is the relay for the lower element( the SWITCH). New timer board is $300 plus on top of the cost of the lower element replacement. I would say the lower element finally gave and as a result it eventually fried the P2-4 terminal/relay connection. I wonder if this is gonna happen every 5 to 7 years of use????:confused:
