Discuss
Cracked glass on oven
 in
I spilled some water on the inside glass of my Kitchenaid Superba oven door and it cracked. Is it safe
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Cracked glass on oven
  #1 (permalink)
Old 02-03-2008, 10:42 PM
wessell wessell is offline
Junior Member
wessell is on a distinguished road
Default Cracked glass on oven
Model Number: KGST307FWH0   Brand: Kitchen Aid   Age: 1 - 5 years
Is it safe to use the oven? Can I replace the glass myself? Help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 03:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If the inner door glass just cracked but still in place you probably can use the oven for cooking but not for the self cleaning.
Due to safety issue it's better to replace it.
This part is not too difficult to replace yourself.
Remove the door from the range and place it on a flat surface with the front of the door facing down.
Remove the screws holding the inner door panel and remove the panel.
The inner door glass comes as a kit and it is much easier to understand the replacement process when you will see the kit.
- The part number for the inner glass kit is AP3124577
Here are the break down diagrams for the Kitchen Aid range Model KGST307FWH0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-04-2008, 05:48 PM
Junior Member
Default Thanks!
I appreciate the information very much. Too bad I broke such an expensive part...
Reply
« robert | robet »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire cracked glass cooktop mchome76 Oven Repair (including Ranges and Cooktops) 3 01-02-2008 01:37 PM
Frigidaire Range glass top cracked Davejb Oven Repair (including Ranges and Cooktops) 4 12-18-2007 07:09 AM
my jenn air glass stove top cracked and broke cowmama48@sbcglobal.net Oven Repair (including Ranges and Cooktops) 0 09-26-2007 10:27 AM
Cracked my oven door window! texasdiver Oven Repair (including Ranges and Cooktops) 3 09-15-2007 07:56 PM
Oh no, I cracked the glass! fsimon Oven Repair (including Ranges and Cooktops) 4 09-08-2007 12:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
