| » Double Oven only beeps |
Model Number: GBD307PRB01 Brand: Whirlpool Age: 5 - 10 years
Hello,
I have looked through several posts about the issue I am having with my double oven and am unclear as to the proper fix. The other day the oven was working fine, then a day later the display is dark and when you hit the "upper oven" button and then start it makes sequential beeps. The light button turns on the light and it appears the timer works, though i cannot see anything. How can I determine if the control board is bad (part 8303883) or if it is a thermal fuse? thanks Ads By Google Related Models |
Hi.
Based on the information you provided the control board is bad Part number: W10340941 Here are the breakdown diagrams and Control Panel parts for Whirlpool GBD307PRB01 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hello, I am trying to get to the control board and cannot seem to get to it, any hints?
I removed the trim from either side fo the oven and removed the screws from part 1 of the control panel diagram (these screws were not going into anything because I do not see a part 7 on my oven). Are there tabs or something that need to be pushed in to get the front panel to come off? thanks |
| Display Modes | |
| GE Profile double oven beeps every 10 seconds, no codes | Brianlinx | Oven Repair (including Ranges and Cooktops) | 3 | 10-30-2012 04:30 PM |
| Whirlpool Double Oven display beeps twice and then goes blank. | Rwf121248 | Oven Repair (including Ranges and Cooktops) | 0 | 05-17-2011 02:06 PM |
| Whirlpool Double Oven No Display but beeps | DIY Fireman | Oven Repair (including Ranges and Cooktops) | 3 | 03-26-2010 07:36 PM |
| whirlpool double oven, only beeps, no display, does not turn on | umairs123 | Oven Repair (including Ranges and Cooktops) | 0 | 02-15-2010 07:17 AM |
| Whirlpool Double Builtin Oven LED OUT, TURNS ON FOR ABOUT 10 SECONDS THEN BEEPS | bearingrnwd | Oven Repair (including Ranges and Cooktops) | 0 | 12-20-2009 07:17 PM |
