Discuss
Whirlpool Range Fault Code F5 E1
 in
WHIRLPOOL FAULT CODE F5 E1.. Trying to diagnosis Oven self cleaning fault code which refers to latch switch or solenoid.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Range Fault Code F5 E1
  #1 (permalink)
Old 01-14-2013, 08:11 PM
Junior Member
steelbuster is on a distinguished road
Default Whirlpool Range Fault Code F5 E1
Model Number: RF386PXEQ0   Brand: Whirlpool   Age: More than 10 years
Whirlpool Range RF386PXEQ0 Self Cleaning Fault... Fault F5 E1 displayed when attempting to use self cleaning feature. The latch, rod and solinoid all move freely when manually manipulated. I did a little checking with a VOM and this is what I found.
No voltage at Door latch Solenoid when control activated. Solenoid shows 57ohms out of circuit. (Solenoid operates when external power applied...) Door Latch Switch is normally Open and Closed ( 0 ohms) when latch mechanism is engaged..Switch seems OK.
When latch is physically closed it mechanically latches shut and the latch switch is closed.
At this point starting the self cleaning cycle still shows same code after a few seconds. I'm wondering if this is a BAD BOARD??? or what am I missing? The control board is expensive so I want to make sure that's the problem.
Ads By Google
Related Models
Whirlpool RF386PXEQ0
Whirlpool RF386PXEQ1
Whirlpool RF386PXEW0
Whirlpool RF386PXEW1
Whirlpool RF386PXEZ0
Whirlpool RF386PXEZ1
Whirlpool RF386PXGB0
Whirlpool RF386PXGB1
Whirlpool RF386PXGB2
Whirlpool RF386PXGB3
Whirlpool RF386PXGB4
Whirlpool RF386PXGN0
Whirlpool RF386PXGN1
Whirlpool RF386PXGN2
Whirlpool RF386PXGN3
Whirlpool RF386PXGN4
Whirlpool RF386PXGQ0
Whirlpool RF386PXGQ1
Whirlpool RF386PXGQ2
Whirlpool RF386PXGQ3
Whirlpool RF386PXGQ4
Whirlpool RF386PXGT2
Whirlpool RF386PXGT3
Whirlpool RF386PXGT4
Whirlpool RF386PXGW0
Whirlpool RF386PXGW1
Whirlpool RF386PXGW2
Whirlpool RF386PXGW3
Whirlpool RF386PXGW4
Whirlpool RF386PXGZ0
Whirlpool RF386PXGZ1
Whirlpool RF386PXGZ2
Whirlpool RF386PXGZ3
Whirlpool RF386PXGZ4
Whirlpool RF387LXGN0
Whirlpool RF387LXGN1
Whirlpool RF387LXGQ0
Whirlpool RF387LXGQ1
Whirlpool RF387LXGW0
Whirlpool RF387LXGW1
Whirlpool RF387LXHQ0
Whirlpool RF387LXHQ1
Whirlpool RF387LXHT1
Whirlpool RF387LXHZ0
Whirlpool RF387LXHZ1
Whirlpool RF387PXPW0
Whirlpool RF387PXVF0
Whirlpool RF387PXVG0
Whirlpool RF387PXVM0
Whirlpool RF387PXVN0
Whirlpool RF387PXVW0
Whirlpool RF387PXWN0
Whirlpool RF387PXWN1
Whirlpool RF387PXWN2
Whirlpool RF387PXWW0
Whirlpool RF387PXWW1
Whirlpool RF387PXWW2
Whirlpool RF388LXGQ0
Whirlpool RF388LXGQ1
Whirlpool RF388LXGQ2
Whirlpool RF388LXGQ3
Whirlpool RF388LXGT3
Whirlpool RF388LXGZ0
Whirlpool RF388LXGZ1
Whirlpool RF388LXGZ2
Whirlpool RF388LXGZ3
Whirlpool RF388LXKB0
Whirlpool RF388LXKP0
Whirlpool RF388LXKQ0
Whirlpool RF388LXKT0
Whirlpool RF389LXKB0
Whirlpool RF389LXKQ0
Whirlpool RF389LXKT0
Whirlpool RF390LXKP0
Whirlpool RF390LXKQ0
Whirlpool RF390LXKT0
Whirlpool RF390PXPW0
Whirlpool RF390PXVN0
Whirlpool RF390PXVW0
Whirlpool RF390PXWN0
Whirlpool RF390PXWN1
Whirlpool RF390PXWN2
Whirlpool RF390PXWW0
Whirlpool RF390PXWW1
Whirlpool RF390PXWW2
Whirlpool RF391PXWW0
Whirlpool RF391PXWW1
Whirlpool RF391PXXW0
Whirlpool RF391PXXW1
Whirlpool RF391PXXW2
Whirlpool RF395LXEB0
Whirlpool RF395LXEQ0
Whirlpool RF395LXEZ0
Whirlpool RF395PCXN0
Whirlpool RF395PCXN1
Whirlpool RF395PCXN2
Whirlpool RF395PCXW0
Whirlpool RF395PCXW1
Whirlpool RF395PCXW2
Whirlpool RF395PXPW0
Whirlpool RF395PXPW1
Whirlpool RF395PXVN0
Whirlpool RF395PXVW0
Whirlpool RF395PXWN0
Whirlpool RF395PXWN1
Whirlpool RF395PXWN2
Whirlpool RF395PXWW0
Whirlpool RF395PXWW1
Whirlpool RF395PXWW2
Whirlpool RF395PXXN0
Whirlpool RF395PXXN1
Whirlpool RF395PXXN2
Whirlpool RF395PXXW0
Whirlpool RF395PXXW1
Whirlpool RF395PXXW2
Whirlpool RF396LXEB0
Whirlpool RF396LXEB1
Whirlpool RF396LXEQ0
Whirlpool RF396LXEQ1
Whirlpool RF396LXEZ0
  #2 (permalink)
Old 01-15-2013, 01:17 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check the wire harness from the door switch and the latch switch to the control board.
Replace the door switch Part number: 3196262
Press and hold any key for 1 min, then press cancel to erase the F2.
If that doesn't take care of the problem - replace the control board Part number: 6610057
Check the color and order the correct one Control Panel parts for Whirlpool RF386PXEQ0 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-16-2013, 05:50 AM
Junior Member
Default
Thanks.. The latch switch and wiring are OK back to the board. I don't believe the door switch is part of the Cleaning Cycle on this model but I will check it before ordering control board.
  #4 (permalink)
Old 01-16-2013, 11:17 AM
Expert
Default
Please post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Range/Oven has F2 fault Code Josie430 Oven Repair (including Ranges and Cooktops) 1 11-23-2012 10:57 AM
Maytag Range fault code jdgriffith Oven Repair (including Ranges and Cooktops) 0 03-23-2011 09:37 AM
f7 fault code from GE gas range covi234 Oven Repair (including Ranges and Cooktops) 0 05-21-2010 07:09 AM
Fault code 7, JEN AIR Gas-Elec Range Bigdigg Oven Repair (including Ranges and Cooktops) 7 03-13-2010 02:54 PM
Jennair Range Top Fault Code pheyden Oven Repair (including Ranges and Cooktops) 1 09-16-2009 03:11 AM
