Discuss
thermador cooktop problems
 in
Hello, I have a thermador SGCS304RS 30" gas cooktop with extra low. The non-xlo burners work fine. Both xlo burners
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » thermador cooktop problems
  #1 (permalink)
Old 01-12-2013, 06:57 PM
Junior Member
billg87 is on a distinguished road
Default thermador cooktop problems
Model Number: SGCS304RS   Brand: Thermador   Age: 5 - 10 years
Hello,
I have a thermador SGCS304RS 30" gas cooktop with extra low. The non-xlo burners work fine. Both xlo burners have problems. One lights at full throttle, but turning it down results in shutoff. The other does not light - no gas. From reading the forum I decided to replace the xlo potentiometers. Instead of buying the expensive potentiometer kit I follwed some other advice and ordered two BSH 422748. Then I ran into the venturi problem, all of my venturis were frozen and I followed Gene's advice not to turn then too far, a good thing too. I planned to drill all of them out, so I ordered 4 venturi tubes, and two of the 12,500 btu jet holders and two 9,100 btu jet holders (BSH 189314 and BSH 414784). I finally got around to repairs today. I drilled out the venturis (oh joy) and got the top off and cleaned everything, replaced the jet holders, and then tried to replace the xlo pots. It was quickly apparent that the pots I ordered were not at all the same. I briefly thought about swapping just the PC boards but decided against it. Instead I ordered the expensive pot kit AP3872616 (497235) with comes with a new simmer control unit. I then put the stove back together trying not to tighten the venturis too much. But now the burners that used to work have LOTS of yellow in the flame, AND, the spark igniter keeps sparking even when flame on.
Regarding the yellow flame, should I replace the orifices with the originals? I notice the originals had 90 and 104 stamps, the new ones have 140 and 170, which I'd guess is diameter? Seems to be way more gas flow now.
And should I replace the spark unit to fix the continuous clicking?
Many thanks for any advice, now that I'm in deep.
Bill
Ads By Google
Related Models
Thermador SGCS304RS
Thermador SGCS304RW
Thermador SGCS365RB
Thermador SGCS365RS
Thermador SGCS365RW
Thermador SGCS456RB
Thermador SGCS456RB S\N 9803
Thermador SGCS456RS
Thermador SGCS456RS S\N 9803
Thermador SGCS456RW
Thermador SGCS456RW S\N 9803
Thermador SGCV36
Thermador SGCV3601
Thermador SGCV36G01
Thermador SGCV36G02
Amana SGD22TL Ref - SXS/I&W
Amana SGD22TW Ref - SXS/I&W
Amana SGD26VL Ref - SXS/I&W
Amana SGD26VW Ref - SXS/I&W
Amana SGD521SBL Ref - SXS/I&W
Amana SGD521SBW Ref - SXS/I&W
Amana SGD521SW Ref - SXS/I&W
Whirlpool SGDS800HQ0
Whirlpool SGDS800JQ0
Whirlpool SGDS800JQ1
Whirlpool SGDS800JQ2
Whirlpool SGDS800MQ0 29"gas Dryer
Whirlpool SGDS800MQ1 29"gas Dryer
Whirlpool SGDX600HQ0
Whirlpool SGDX600JQ0
Whirlpool SGDX600JQ1
Whirlpool SGDX600JQ2
Whirlpool SGDX600MQ0 29"gas Dryer
Whirlpool SGDX600MQ1 29"gas Dryer
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
Thermador SGN30B
Thermador SGN30S
Thermador SGN30W
Thermador SGN36GB
Thermador SGN36GS
Thermador SGN36GW
Thermador SGNCV36GB
Thermador SGNCV36GS
Thermador SGNCV36GW
Whirlpool SGP335XW0
Whirlpool SGP335XW1
Whirlpool SGP335XX2
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B
Thermador SGS30S
Thermador SGS30W
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB
Thermador SGS36GS
Thermador SGS36GW
Whirlpool SGS375HQ0
Whirlpool SGS375HQ5
Whirlpool SGS375HQ6
Whirlpool SGS375HQ7
Whirlpool SGS395XX0
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB
Thermador SGSCV36GS
Thermador SGSCV36GW
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
Thermador SGSX456ZB
Thermador SGSX456ZS
Thermador SGSX456ZW
Thermador SGT3001
Thermador SGT3002
Thermador SGT36
Thermador SGT3601
Thermador SGT36G01
Thermador SGT36G02
Frigidaire SGWS1349AS0 Frigidaire/washer
  #2 (permalink)
Old 01-12-2013, 07:35 PM
Junior Member
Default
Follow up. I opened it back up and replaced the orifices with the smaller ones that were there originally. And now the flames are blue and the spark igniter doesn't repeat. So now I'm back to where I started. I'm guardedly optimistic that the new pot kit will completely fix it.
Bill
  #3 (permalink)
Old 01-19-2013, 07:40 PM
Junior Member
Default
OK, today I replaced the two extra-low potentiometers and the simmer control and fired it up. The burner that used to work only at full blast now can be turned down to the xlo range, however the xlo range doesn't seem to turn it down any further, rather it sits for a while and usually goes out. But at least it is a functional burner. The last burner is still non-functional, it won't light - no gas. I don't hear the thunk of the solenoid so I assume that's the next part to replace. Does anyone have experience with the x-lo burners?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador oven problems seltzd Oven Repair (including Ranges and Cooktops) 3 09-17-2012 12:13 PM
problems with thermador cmt 227 ninamoo Oven Repair (including Ranges and Cooktops) 0 03-22-2011 09:48 AM
Problems with Thermador Cook n Vent Bill2 Oven Repair (including Ranges and Cooktops) 3 02-18-2011 01:47 PM
Problems with Thermador Cook n Vent lzurcher Oven Repair (including Ranges and Cooktops) 2 02-17-2011 06:58 PM
Thermador Cooktop Ignitor problems fifties Oven Repair (including Ranges and Cooktops) 0 03-02-2009 03:58 PM
