Discuss
How do I remove upper oven door
 in
How do I remove the upper oven door on a Thermatronic II CMT-20? Do I need to pull the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How do I remove upper oven door
  #1 (permalink)
Old 01-11-2013, 04:24 PM
Junior Member
BHAZELETT is on a distinguished road
Default How do I remove upper oven door
Model Number: CMT-20   Brand: Thermador   Age: More than 10 years
How do I remove the upper oven door on a Thermatronic II CMT-20? Do I need to pull the oven out from the wall to access a hinge release?
Ads By Google
Related Models
Thermador CMT-20
Thermador CMT-21
Thermador CMT-21 SERVICE CODE J & UP
Thermador CMT-227
Thermador CMT-231
Whirlpool CMT061SGW0
Whirlpool CMT101SGW0
Whirlpool CMT102SGW0
Thermador CMT127N-01
Whirlpool CMT135SGW0
Thermador CMT227N-01
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
Maytag CMV1100AAQ Mwave - Mounted Under Cabinet
Maytag CMV1100AAW Mwave - Mounted Under Cabinet
Crosley CMW159PC Mwave - Cntrtp / Stand Alone
Crosley CMW22A2 Mwave - Cntrtp / Stand Alone
Crosley CMW22A6 Mwave - Cntrtp / Stand Alone
Crosley CMW419PD Mwave - Cntrtp / Stand Alone
Crosley CMW464G Mwave - Cntrtp / Stand Alone
Maytag CNDNS229J  Ref - SXS/I&W
Maytag CNDNS229JA  Ref - SXS/I&W
Maytag CNDNS229JH  Ref - SXS/I&W
Maytag CNDNS229K  Ref - SXS/I&W
Maytag CNDNS229KA  Ref - SXS/I&W
Maytag CNE200 Range - F/s Std Ele
Maytag CNE2000ACL Range - F/s Std Ele
Maytag CNE2000ACW Range - F/s Std Ele
Admiral CNEA100ACL Range - F/s Std Ele
Admiral CNEA100ACW Range - F/s Std Ele
Maytag CNG200 Range - F/s Std Gas
Maytag CNG201 Range - F/s Std Gas
Maytag CNG2010AAL Range - F/s Std Gas
Maytag CNG2010AAW Range - F/s Std Gas
Maytag CNG2010BAL Range - F/s Std Gas
Maytag CNG2010BAW Range - F/s Std Gas
Maytag CNNS208  Ref - Sxs
Maytag CNNS208H  Ref - Sxs
Norge CNNS208K Ref - Sxs
Norge CNNS208KA Ref - Sxs
Norge CNNS208KW Ref - Sxs
Maytag CNNT153L  Ref - Top Mount
Maytag CNNT153LA  Ref - Top Mount
Maytag CNNT156K  Ref - Top Mount
Maytag CNNT156KA  Ref - Top Mount
Maytag CNNT156KH  Ref - Top Mount
Maytag CNNT156KL  Ref - Top Mount
Norge CNNT174HL Ref - Top Mount
Norge CNNT174HLA Ref - Top Mount
Norge CNNT174HLH Ref - Top Mount
Maytag CNNT174K  Ref - Top Mount
Maytag CNNT174KA  Ref - Top Mount
Maytag CNNT174KL  Ref - Top Mount
Maytag CNNT174KLA  Ref - Top Mount
Norge CNNT178BV Ref - Top Mount
Norge CNNT178BVA Ref - Top Mount
Norge CNNT178BVH Ref - Top Mount
Maytag CNNT198GA  Ref - Top Mount
Maytag CNNT198GH  Ref - Top Mount
Maytag CNNT198GL Ref - Top Mount
Maytag CNNT198GLA  Ref - Top Mount
Maytag CNNT198GLH  Ref - Top Mount
Maytag CNNT198GLN Ref - Top Mount
Maytag CNNT198GN  Ref - Top Mount
Maytag CNNT198K  Ref - Top Mount
Maytag CNNT198KA  Ref - Top Mount
Maytag CNNT198KL  Ref - Top Mount
Maytag CNNT198KLA  Ref - Top Mount
Crosley CNNT218BV Ref - Top Mount
Crosley CNNT218BVA Ref - Top Mount
Crosley CNNT218BVH Ref - Top Mount
Maytag CNP200 Range - F/s Std Gas
Maytag CNP201 Range - F/s Std Gas
Maytag CNP2010AXL Range - F/s Std Gas
Maytag CNP2010AXW Range - F/s Std Gas
Maytag CNP2010BXL Range - F/s Std Gas
Maytag CNP2010BXW Range - F/s Std Gas
Admiral CNPA100AXL Range - F/s Std Gas
Admiral CNPA100AXW Range - F/s Std Gas
Crosley CNS20M4 Ref - Sxs
Crosley CNS20M4A Ref - Sxs
Crosley CNS20M4H Ref - Sxs
Crosley CNS20M6 Ref - Sxs
Crosley CNS20M6A Ref - Sxs
Crosley CNS20M6H Ref - Sxs
Crosley CNS20T6 Ref - Sxs
Crosley CNS20T6A Ref - Sxs
Crosley CNS20T6H Ref - Sxs
Crosley CNS22M6 Ref - Sxs
Crosley CNS22M6A Ref - Sxs
Crosley CNS22M6H Ref - Sxs
Crosley CNS22T6 Ref - Sxs
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to remove oven door hinge after door is removed? stilllearning6 Oven Repair (including Ranges and Cooktops) 1 04-28-2012 08:19 PM
Upper Oven Element Remove and Install Topnotch Oven Repair (including Ranges and Cooktops) 0 01-13-2011 11:49 AM
Replace inner glass panel on upper oven door gabaldini@gmail.com Oven Repair (including Ranges and Cooktops) 2 05-26-2010 07:22 AM
Installing new inner door glass upper oven Lloyd Duncan Oven Repair (including Ranges and Cooktops) 0 03-25-2010 11:50 AM
What part(s) do I need to repair upper oven door Kaliman Oven Repair (including Ranges and Cooktops) 7 12-11-2008 09:19 AM
