problem with gas range
Our GE Profile XL44 stove/oven is not working.When more than one burner is on at the same time, or when the oven is on, the range top loses flame. The oven also takes forever to come up to temp, regardless of whats on on the cook top.
Hi.
Sounds like the pressure regulator is bad. Please post the complete model number of the range, I'll trade it for the part number. Simon. |
Model # JGBP86BEA3BB
The broiler did not flame up the other day while stovetop was running. Could that also be the regulator, or might there also be an ignitor problem? |
Hi.
You may have two separate problems.Replace the regulator first, that may take care of the problem. The regulator Part number: WB19K10001 Here are the breakdown diagrams and Gas Burner parts for GE JGBP86BEA3BB - AppliancePartsPros.com Post the results. Simon. |
| All times are GMT -7. The time now is 12:13 PM. |
