Discuss
Identifying a bulb
 in
I simply need to replace a blown halogen light bulb. This is proving to be an incredible difficult task as
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Identifying a bulb
  #1 (permalink)
Old 01-08-2013, 10:05 AM
Junior Member
94dgrif is on a distinguished road
Default Identifying a bulb
Model Number: 66598013801   Brand: Kenmore   Age: 1 - 5 years
I simply need to replace a blown halogen light bulb. This is proving to be an incredible difficult task as no one seems to know what bulb I need!
The bulb in question is for the 'Halogen Lamp' found here.
The Range itself can be found here.
Hints about the bulb
Bulb: Nothing written on the bulb whatsoever
Glass lens: Has the words '120V 25W max' written on it
Metal heat shield: '100W' punched onto it
Manual: "120-volt, 20-watt maximum halogen bulb"
Appliancepartspros.com: Their Q/A for the lamp links here to a 12V 10W bulb.
Sears parts tech support: Have no information on the bulb whatsoever, and suggest I replace the whole lamp assembly.
Physical dimensions: 2 pins at 8mm ish in length, 5mm ish from pin tip to pin tip, 1.5mm ish pin thickness, 30mm glass section plus 3mm nipple.
Researching the net has shown me this is probably a G5 or G5.3 (or GU_, GY_ etc for those sizes) bulb. Frankly I imagine either one is close enough to physically push in. What worried me most is the voltage and watt rating. I would be looking for a 120V, 20W bulb to satisfy the manual, lens and heat shield, but APP seem confident on the 12V 10W rating (a chat with a rep of theirs confirmed their view).
Is there a way to tell the difference between a 12V and 120V bulb? For example maybe they physically look different, perhaps the latter has more coils, or maybe a multimeter on the fixture would indicate something, or there's some other easy method?
Any and all help will be gratefully received!
Related Models
Kenmore 66598013801 ELECTRIC RANGE
Kenmore 66598019700 FREE STANDING ELECTRIC RANGE
Kenmore 66598019801 ELECTRIC RANGE
Kenmore 6659898990 MICROWAVE OVEN
Admiral 665AG-CHZ RANGE- S/C F/S ELE
Admiral 665AH-CV RANGE- S/C F/S ELE
Admiral 665AH-CVW RANGE- S/C F/S ELE
Admiral 665HG-CHZ RANGE- S/C F/S ELE
Admiral 665HH-CV RANGE- S/C F/S ELE
Kenmore 665KUDI23BWH0 DISHWASHER
Kenmore 665KUDI23HB0 DISHWASHER
Kenmore 665KUDS23HB0 DISHWASHER
Kenmore 665KUDS23HBAL0 DISHWASHER
Kenmore 665KUDS23HBWH0 DISHWASHER
Admiral 665WG-CHZ RANGE- S/C F/S ELE
Admiral 665WH-CV RANGE- S/C F/S ELE
Admiral 665WH-CVW RANGE- S/C F/S ELE
Admiral 666AJ-ESAW RANGE- S/C F/S ELE
Admiral 666AJ-ESVW RANGE- S/C F/S ELE
Admiral 666AJ-THVW RANGE- S/C F/S ELE
Admiral 666KJ-ESVW RANGE- S/C F/S ELE
Admiral 666WJ-ESAW RANGE- S/C F/S ELE
Admiral 666WJ-ESVW RANGE- S/C F/S ELE
Admiral 666WJ-THVW RANGE- S/C F/S ELE
Admiral 667AJ-TSAW RANGE- S/C F/S ELE
Admiral 667AK-TSAW RANGE- S/C F/S ELE
Admiral 667AK-TSVW RANGE- S/C F/S ELE
Admiral 667KK-TSAW RANGE- S/C F/S ELE
Admiral 667KK-TSVW RANGE- S/C F/S ELE
Admiral 667WJ-TSAW RANGE- S/C F/S ELE
Admiral 667WK-TSAW RANGE- S/C F/S ELE
Admiral 667WK-TSVW RANGE- S/C F/S ELE
Admiral 668AJ-ASAW RANGE- S/C F/S ELE
Admiral 668AK-TSAW RANGE- S/C F/S ELE
Admiral 668WJ-ASAW RANGE- S/C F/S ELE
Admiral 668WK-TSAW RANGE- S/C F/S ELE
Maytag 66CB MAYTAG LAUNDRY (DRYER GAS)
Hoover 67
Hoover 671
Admiral 671AH RANGE- F/S STD GAS
Admiral 671AH-K RANGE- F/S STD GAS
Admiral 671WH RANGE- F/S STD GAS
Admiral 671WH-K RANGE- F/S STD GAS
Admiral 673AJ-KV RANGE- F/S STD GAS
Admiral 673WJ-KV RANGE- F/S STD GAS
Admiral 674AJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674AJ-EKVW RANGE- F/S STD GAS
Admiral 674AJ-EKW RANGE- F/S STD GAS
Admiral 674WJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674WJ-EKVW RANGE- F/S STD GAS
Admiral 674WJ-EKW RANGE- F/S STD GAS
Admiral 675AJ-KVW RANGE- F/S STD GAS
Admiral 675AK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675AK-KVW RANGE- F/S STD GAS
Admiral 675AM-KSVW RANGE- F/S STD GAS
Admiral 675WJ-KVW RANGE- F/S STD GAS
Admiral 675WK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675WK-KVW RANGE- F/S STD GAS
Admiral 675WM-KSVW RANGE- F/S STD GAS
Admiral 676AJ-KSVW RANGE- F/S STD GAS
Admiral 676AK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AK-KSVW RANGE- F/S STD GAS
Admiral 676AM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AM-KSVW RANGE- F/S STD GAS
Admiral 676WJ-KSVW RANGE- F/S STD GAS
Admiral 676WK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WK-KSVW RANGE- F/S STD GAS
Admiral 676WM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WM-KSVW RANGE- F/S STD GAS
Maytag 67C DRYER- GAS
Hoover 68
Frigidaire 68-1075 TAPPAN DISHWASHER
Frigidaire 68-1085 TAPPAN 24" BUILT-IN DISHWASHER
Magic Chef 68-2534-40 GAS RANGE
Magic Chef 68-253657 GAS RANGE
Magic Chef 68-2543-80 GAS RANGE
Magic Chef 68-2543-87 GAS RANGE
Magic Chef 68-2558-40 GAS RANGE
Magic Chef 68-255850 GAS RANGE
Magic Chef 68-255857 GAS RANGE
Magic Chef 68-2563-87 GAS RANGE
Magic Chef 68-2593-80 GAS RANGE
Magic Chef 68-2593-81 GAS RANGE
Magic Chef 68-2593-87 GAS RANGE
Hardwick 68-2598 GAS RANGE
Magic Chef 68-454650 ELECTRIC RANGE
Magic Chef 68-454657 ELECTRIC RANGE
Magic Chef 68-4567-40 ELECTRIC RANGE
Magic Chef 68-456750 ELECTRIC RANGE
Magic Chef 68-456751 ELECTRIC RANGE
Magic Chef 68-456757 ELECTRIC RANGE
Magic Chef 68-4585-40 ELECTRIC RANGE
Magic Chef 68-4587-87 ELECTRIC RANGE
Hoover 681
Admiral 684AJ-CKV RANGE- S/C F/S GAS
Admiral 684WJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKVW RANGE- S/C F/S GAS
Admiral 685WJ-CKV RANGE- S/C F/S GAS
Admiral 685WJ-CKVW RANGE- S/C F/S GAS
Admiral 686AJ-EKSVW RANGE- S/C F/S GAS
Admiral 686AJ-TKSVW RANGE- S/C F/S GAS
Admiral 686AK-EKSVW RANGE- S/C F/S GAS
Admiral 686AM-CKSV RANGE- S/C F/S GAS
Admiral 686AM-TKS RANGE- S/C F/S GAS
Admiral 686WJ-EKSVW RANGE- S/C F/S GAS
Admiral 686WJ-TKSVW RANGE- S/C F/S GAS
Admiral 686WK-EKSVW RANGE- S/C F/S GAS
Admiral 686WM-CKSV RANGE- S/C F/S GAS
Admiral 686WM-TKS RANGE- S/C F/S GAS
Admiral 687AF-CKVW RANGE- S/C F/S GAS
Admiral 687AJ-EKZW RANGE- S/C F/S GAS
Admiral 687AJ-TKSAW RANGE- S/C F/S GAS
Admiral 687AK-TKSAW RANGE- S/C F/S GAS
Admiral 687AM-TKSAW RANGE- S/C F/S GAS
Admiral 687WF-CKVW RANGE- S/C F/S GAS
Admiral 687WJ-EKZW RANGE- S/C F/S GAS
Admiral 687WJ-TKSAW RANGE- S/C F/S GAS
Admiral 687WK-TKSAW RANGE- S/C F/S GAS
Admiral 687WM-TKSAW RANGE- S/C F/S GAS
  #2 (permalink)
Old 01-08-2013, 03:58 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
According the model number this oven has two lights. One is regular and one is halogen. The regular is 120V and halogen is 12v.
Here is the non halogen light bulb Part number: 8009
Part number: 8009
Click on the sign to see the picture.
Here is the halogen bulb Part number: 74009970
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-10-2013, 01:42 PM
Junior Member
Default
Hi Simon,
I really appreciate the work you put into researching this. It looks like all my links other than the appliancepartspro.com ones were removed. The one I labelled 'Halogen Lamp' was the same as the one you posted, albeit to the searsdirect website. The problem is that this part is the entire lamp (bulb + lens + heatshield + socket + wiring + connector) rather than just the bulb, which is the only part that's actually bad.
I'm skeptical about using a 12V bulb as the manual states:
"The ovens use either a 120-volt, 20-watt maximum halogen bulb and/or a standard 40-watt appliance bulb."
So the arguments for this being a 120V are that the glass lens and manual both indicate 120V. The arguments that it's a 12V bulb are exclusively from appliancepartspros (here, the online chat and the webpage I linked). I'm open to either being correct, but obviously they both can't be, and each incorrect guess will cost $20 a pop (literally).
Is there a way to eyeball or test the bulb or fixture to ascertain the appropriate voltage?
  #4 (permalink)
Old 01-10-2013, 03:08 PM
Expert
Default
Hi.
Are you able to tell the difference between regular incandescent bulb and tiny halogen bulb?
Which one do you have?
Simon.
__________________
  #5 (permalink)
Old 01-10-2013, 05:50 PM
Junior Member
Default
Yes, I am able to tell the difference between an incandescent and halogen bulb. The bulb I'm trying to replace (the 40~mm bulb shown within this lamp fixture) is most certainly a halogen bulb.
It looks similar to, for example, this 120V 20W bulb, or this 12V 5W bulb.
  #6 (permalink)
Old 01-11-2013, 02:46 PM
Expert
Default
Hi.
After the research the conclusion is to replace the kit, which is recommended by the manufacturer. The single bulb is not sold any more for this model (the handling of the halogen bulb will shorten it's life), that's why it's not listed by itself.
You will have to order the kit.
You may return this part back without any questions asked.
Thank you.
Simon.
__________________
  #7 (permalink)
Old 01-12-2013, 03:07 PM
Junior Member
Default
Thank you Simon, I know you've spent a lot of time on this problem.
I am already aware that they no longer sell the bulb as a separate part, and that handling of the bulb shortens it's lifespan. So long as the bulb is clean (including no organic oils like fingerprints, dust etc) it should still be fine.
I'm going to continue trying to identify the bulb and will replace it if I'm successful. For anyone with the same problem that happens upon this thread, I suspect the bulb is a 120V 20W halogen G5.3. I haven't been able to confirm that, but it does seem the most plausible based on the measurements and various references.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help identifying microwave emmer00 Microwave Repair 1 11-29-2012 03:13 PM
How to replace light bulb inside micro. can't find bulb location mcolleran Microwave Repair 0 07-30-2011 07:44 PM
Help Identifying a Part cwlong88 Dishwasher Repair 2 05-06-2010 07:18 PM
hoodvent fan and light out after touching broken off light bulb with new bulb threads dtseckinger Microwave Repair 1 04-27-2009 07:21 PM
help identifying part washerguy08 Washer Repair 0 11-30-2008 12:07 AM
