| » Thermador double oven control panel |
Model Number: SC302ZS Brand: Thermador Age: 5 - 10 years
Our Thermador SC302ZS double oven has had two displays replaced by our local repair service due to dim readout display. I purchased the 702451 double oven kits from you guys to repair myself and not pay $700 plus for the repair. Before replacing the circuit board I noted where all wires were placed by taking several pictures of the board before removing. I turned the main breaker off to the oven before removing any wires. I removed and checked the board against the new board and All connections were identical. I installed the new board then removed the LED display and checked it against the new display. I noticed that the new board had a 6 pin connection that the original board does not have, therefore no wires in the oven to connect to this connection. I installed the display as the display face was identical and obviously for a double oven. Once installed I powered up the oven and found that the oven interior lights were on and can't be turned off by pushing the light button. I tried all functions and both ovens operate perfectly on bake and broil settings. However clean cycles will not work. The original display was manufactured by Invensys Controls with a number 100-01044-02 and a CN 5020009942.
Do you have any idea why the oven light will not turn off and cleaning will not operate? Ads By Google Related Models |
| Display Modes | |
| GE double oven control panel | Chrisrubz | Oven Repair (including Ranges and Cooktops) | 0 | 11-22-2010 08:51 AM |
| double oven control panel | obringer | Oven Repair (including Ranges and Cooktops) | 0 | 10-12-2010 11:50 PM |
| GE Double Oven Control Panel replacement | robwinter | Oven Repair (including Ranges and Cooktops) | 0 | 12-12-2009 11:52 AM |
| Double Oven control Panel | nansells | Oven Repair (including Ranges and Cooktops) | 2 | 05-25-2009 04:41 PM |
| Thermador SCD302 double oven touch control failure | boonjh | Oven Repair (including Ranges and Cooktops) | 1 | 02-12-2009 07:34 PM |
