Frigidaire Range FEF365ASG won't bake or heat oven chamber
A year or so ago, the bottom bake element of this oven cracked in two. I replaced the part at that time and it worked fine since. Now it is back to not baking/heating again in the main chamber. However, this time the bake element did not crack in half and looks fine. So, I'm not sure what to do? Everything else is working fine. Do you think it could be the bake element even though it looks fine, or something else. I don't want to guess if I can avoid it. Thanks! |
Hi.
If the broil doesn't work also, check if the unit getting 240VAC. If it does - replace the clock/control board Part number: 316207510 Here are the breakdown diagrams and Backguard parts for Frigidaire FEF365ASG - AppliancePartsPros.com Post the results. Simon. |
| All times are GMT -7. The time now is 05:32 AM. |
