Discuss
How to wire 12002125 dual switch for a single burner
 in
I have purchased a 12002125, which is a dual switch and am trying to install it on my Jenn Air
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to wire 12002125 dual switch for a single burner
  #1 (permalink)
Old 01-07-2013, 09:48 AM
Junior Member
fyao is on a distinguished road
Default How to wire 12002125 dual switch for a single burner
Model Number: CVE3401B   Brand: Jenn-Air   Age: 5 - 10 years
I have purchased a 12002125, which is a dual switch and am trying to install it on my Jenn Air CVE3401B cooktop. We followed the instructions that came with the part and separated the double red wire and inserted the jumper. Now when we switch it on, the indicator light came up but the burner is not heating up.
Now the burner we are trying to install the switch to is the right rear one, the small single burner on the right. The power comes first to the switch of the right front burner (which is a dual burner), which has all the yellow wire, one double red wire and one single red wire. However, the old switch for the right rear burner only has one double red wire and no yellow wire. We did put the jumper in according to the instructions.
Can someone help us and see which wire should be connected differently (if that is the case) for a single burner. I saw a similar posting on the forum that says that he could only get the indicator light to come on but not the burner. He also said that when he switched some connection, he could get the burner on but not the indicator light. Finally, he go help and set the connections right, but he did not mention how.
Ads By Google
Related Models
Jenn-Air CVE3401B Surface Unit - Ddraft Ele
Jenn-Air CVE3401Q Surface Unit - Ddraft Ele
Jenn-Air CVE3401W Surface Unit - Ddraft Ele
Jenn-Air CVE407B Surface Unit - Ddraft Ele
Jenn-Air CVE407B-C Surface Unit - Ddraft Ele
Jenn-Air CVE407W Surface Unit - Ddraft Ele
Jenn-Air CVE407W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180B Surface Unit - Ddraft Ele
Jenn-Air CVE4180B-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180S Surface Unit - Ddraft Ele
Jenn-Air CVE4180S-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180W Surface Unit - Ddraft Ele
Jenn-Air CVE4180W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270B Surface Unit - Ddraft Ele
Jenn-Air CVE4270B-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270S Surface Unit - Ddraft Ele
Jenn-Air CVE4270S-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270W Surface Unit - Ddraft Ele
Jenn-Air CVE4270W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4370B Surface Unit - Ddraft Ele
Jenn-Air CVE4370W Surface Unit - Ddraft Ele
Jenn-Air CVEX4100B Surface Unit - Ddraft Ele
Jenn-Air CVEX4100W Surface Unit - Ddraft Ele
Jenn-Air CVEX4270B Surface Unit - Ddraft Ele
Jenn-Air CVEX4270W Surface Unit - Ddraft Ele
Jenn-Air CVEX4370B Surface Unit - Ddraft Ele
Jenn-Air CVEX4370W Surface Unit - Ddraft Ele
Jenn-Air CVG2420B Surface Base Unit - Ddraft Gas
Jenn-Air CVG2420W Surface Base Unit - Ddraft Gas
Jenn-Air CVG316B Surface Unit - Ddraft Gas
Jenn-Air CVG316W Surface Unit - Ddraft Gas
Jenn-Air CVG4100B Surface Unit - Ddraft Gas
Jenn-Air CVG4280B Surface Unit - Ddraft Gas
Jenn-Air CVG4280S Surface Unit - Ddraft Gas
Jenn-Air CVG4280W Surface Unit - Ddraft Gas
Jenn-Air CVG4380B Surface Unit - Ddraft Gas
Jenn-Air CVG4380P Surface Unit - Ddraft Gas
Jenn-Air CVG4380PD Surface Unit - Ddraft Gas
Jenn-Air CVG4380PF Surface Unit - Ddraft Gas
Jenn-Air CVG4380PG Surface Unit - Ddraft Gas
Jenn-Air CVG4380PK Surface Unit - Ddraft Gas
Jenn-Air CVG4380PR Surface Unit - Ddraft Gas
Jenn-Air CVG4380PU Surface Unit - Ddraft Gas
Jenn-Air CVG4380W Surface Unit - Ddraft Gas
Jenn-Air CVGX2423B Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423Q Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423W Surface Base Unit - Ddraft Gas
Whirlpool CVR1000
Whirlpool CVR2000
Whirlpool CVR3000
Whirlpool CVR500
Whirlpool CVR600
Whirlpool CVR6001
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid dual burner on ceramic stovetop will not turn on for the single burner schmidtjl@cni.net Oven Repair (including Ranges and Cooktops) 1 02-02-2011 11:47 AM
Single/dual Burner Wont Turn Off rfox Oven Repair (including Ranges and Cooktops) 0 08-22-2010 01:38 PM
Where does blue wire go on dual infinite switch? amoore Oven Repair (including Ranges and Cooktops) 3 01-21-2010 11:33 PM
Dual switch to single switch substitution jcsimonich Oven Repair (including Ranges and Cooktops) 0 11-09-2009 05:11 PM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 01:04 PM
