| » Where can I get a fan switch? |
Model Number: C236B Brand: Jenn-Air Age: More than 10 years
I need to replace a fan switch on my Jenn-Air cooktop model C236B. They don't make new parts anymore. Any ideas for finding a used part?
Remove the switch and take it with you to a electronics supply house, they may be able to find a replacement for you.
If the switch has more than 2 wires be sure to mark where they go. Switches usually have a manufactures part number and voltage with current ratings on them.
__________________
| Display Modes | |
| GE Oven - Which limit switch is one time thermal switch(two are close on diagram) | personalt | Oven Repair (including Ranges and Cooktops) | 2 | 04-26-2011 04:57 AM |
| Maytag dryer switch went bad (I thought) but new switch is doing the same thing. | woof | Dryer Repair | 1 | 11-19-2010 01:53 AM |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 5 | 11-24-2009 02:14 PM |
| GE Cooktop - Heat Switch + Select Switch | dtshenoy | Oven Repair (including Ranges and Cooktops) | 3 | 06-06-2009 03:14 PM |
| cycle switch or motor switch fails | andygregg | Washer Repair | 2 | 01-28-2009 10:25 AM |
