| » oven over heating |
Model Number: gbs307prb01 Brand: Whirlpool Age: 5 - 10 years
my wall oven gets error code e2f3, when bake is pressed it heats up for a while then switches to broil and locks up. i have replaced heat sensor but issue continues wht else could it be?
Parts for Whirlpool GBS307PRB01 Wall Oven - AppliancePartsPros.com See the attachment for your tech sheet Odds are that the control board (item 5 in the Control Panel parts) is shot. Click on the part's picture for more info on it.
__________________
Quote:
was doing some research while waiting for reply, i came accross the thermostat. is it possible the thermostat could have gone bad....i have had this replaced a couple of years ago |
Quote:
yes i did replace heat sensor inside the oven, but there is a thermostat in back of the unit as well just wondering if this could also be the problem |
Quote:
i think its also called thermal overlod |
Quote:
i think its also called thermal overload |
| Display Modes | |
| The oven won't heat up. The pilot is lit and not heating oven | Hazelave.corp | Oven Repair (including Ranges and Cooktops) | 1 | 11-21-2012 10:23 PM |
| Oven door opens when in use causing oven to stop heating | puck | Oven Repair (including Ranges and Cooktops) | 3 | 03-14-2009 07:25 AM |
| Bottom heating element in oven not heating | Bill Pitts | Oven Repair (including Ranges and Cooktops) | 1 | 03-07-2009 06:02 PM |
| Frigidaire Double Oven/ Top oven not heating | dross3491 | Oven Repair (including Ranges and Cooktops) | 6 | 12-14-2008 12:33 PM |
| GE Wall Double Oven Top Oven Not Heating | ryoung | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2008 08:02 PM |
