| » ge wall oven wont heat up |
The fan will run off of half the line (120 volts) but the elements require the full 240 so i would check the power first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!! Could also be the oven sensor if the control shows that the oven is ready. Or could be your control board/timer is toast.
__________________
| Display Modes | |
| Double wall oven panel wont work and oven won't go on | Pat T | Oven Repair (including Ranges and Cooktops) | 1 | 03-31-2012 04:19 AM |
| magic chef wall oven wont heat up.it ignites | barbara1 | Oven Repair (including Ranges and Cooktops) | 1 | 09-10-2010 04:23 PM |
| Jen Air electric wall oven wont heat | zekec | Oven Repair (including Ranges and Cooktops) | 0 | 03-27-2009 10:29 AM |
| wall oven wont go below 350 | david93950 | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2007 11:01 AM |
