Discuss
Burnt igniter wiring on old GE gas oven - why?
 in
My gas oven (GE JGRS14GEP2BG, probably 20 years old) won’t heat past 370F. The bake burner always stays on trying
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burnt igniter wiring on old GE gas oven - why?
  #1 (permalink)
Old 01-04-2013, 03:20 PM
Junior Member
akstens is on a distinguished road
Default Burnt igniter wiring on old GE gas oven - why?
Model Number: JGRS14GEP2BG   Brand: GE   Age: More than 10 years
My gas oven (GE JGRS14GEP2BG, probably 20 years old) won’t heat past 370F. The bake burner always stays on trying to raise the temp.
Today I removed the igniter and it Ohmed out at 100 Ohms, so I think that it’s still good (ignition occurs within 60 seconds). However, I noticed some of the igniter wiring was burnt and the plastic insulation cracked off, exposing bare wire on both ignitor orange wires. I suspect the bare wire is shorting to the chassis, causing the gas safety valve to not open fully, resulting in low max oven temperature. The thing I can’t figure out is why did the wiring melt? Specifically, it is not the white fabric-wrapped six inch igniter wires that melted, it is the next six inches of orange wire from the igniter ceramic wire nuts running back into the oven that were affected. Although replacing an igniter seems idiot-proof, here’s what I suspect: I replaced this igniter six years ago. Once installed, the igniter wires enter thru a hole in the burner chamber sheet metal and go into an inner chamber about one inch deep, and then continue thru a second small hole in another sheet metal panel toward the rear of the oven. There is no way to control how the wires bunch up once the igniter is bolted in place. I suspect the wires bunched up in that inner cavity and got too hot in there. Maybe the two igniter wires are supposed to run straight thru both sheet metal holes without any slack? If so, how do you get them routed properly? I cannot guarantee such routing of wires from the front side. The wires are not stiff enough and the ceramic nuts get in the way, and access thru the first hole is too small.
Is the solution to remove the oven from the wall and make sure the wires are routed absolutely straight thru both sets of sheet metal holes to prevent overheating? If so, I’m surprised this never gets discussed in these forums, and that the ovens are designed such that the DIYer cannot ensure safe wire routing without removing the whole oven and working from the back side. Any ideas? Thanks!
Ads By Google
Related Models
General Electric JGRS14GEP2BG Electric range
General Electric JGRS14GET1BB Gas range
General Electric JGRS14GET2BB Gas range
General Electric JGRS14GEV1BB Gas range
General Electric JGRS15GEL1 Gas range
General Electric JGRS15GEL2 Gas range
General Electric JGRS15GEL3 GAS RANGE
General Electric JGRS15GEL4 GAS RANGE
General Electric JGS505GEV2BB Gas range
Jenn-Air JGS8750ADB RANGE- S/C S/I GAS
Jenn-Air JGS8750ADS RANGE- S/C S/I GAS
Jenn-Air JGS8750ADW RANGE- S/C S/I GAS
Jenn-Air JGS8750BDB RANGE- S/C S/I GAS
Maytag JGS8750BDB16 30" GAS SLIDE-IN NON-CONVECTION
Jenn-Air JGS8750BDS RANGE- S/C S/I GAS
Maytag JGS8750BDS17 30" GAS SILDE-IN NON-CONVECTION
Jenn-Air JGS8750BDW RANGE- S/C S/I GAS
Maytag JGS8750BDW16 30" GAS SLIDE-IN NON-CONVECTION
Maytag JGS8750CDB00 30" GAS SLIDE-IN
Maytag JGS8750CDS00 30" GAS SLIDE-IN
Jenn-Air JGS8750CDS01 30" GAS SLIDE-IN
Jenn-Air JGS8850ADB RANGE- S/C S/I GAS
Jenn-Air JGS8850ADQ RANGE- S/C S/I GAS
Jenn-Air JGS8850ADS RANGE- S/C S/I GAS
Jenn-Air JGS8850ADW RANGE- S/C S/I GAS
Jenn-Air JGS8850BDB RANGE- S/C S/I GAS
Jenn-Air JGS8850BDQ RANGE- S/C S/I GAS
Jenn-Air JGS8850BDS RANGE- S/C S/I GAS
Maytag JGS8850BDS17 30" GAS SLIDE-IN
Jenn-Air JGS8850BDW RANGE- S/C S/I GAS
Maytag JGS8850CDB00 30" GAS SLIDE-IN
Maytag JGS8850CDS00 30" GAS SLIDE-IN
Jenn-Air JGS8850CDS01 30" GAS SLIDE-IN
Jenn-Air JGS8850CDS02 30" GAS SLIDE-IN RANGE
Maytag JGS8850CDW00 30" GAS SLIDE-IN
Jenn-Air JGS8860BDP RANGE- S/C S/I GAS
Maytag JGS8860BDP17 30" GAS SLIDE-IN
General Electric JGS905BEK1BB Gas range
General Electric JGS905BEK2BB Gas range
General Electric JGS905BEK3BB Gas range
General Electric JGS905KEK1CC Gas range
General Electric JGS905KEK2CC Gas range
General Electric JGS905KEK3CC Gas range
General Electric JGS905SEK1SS Gas range
General Electric JGS905SEK2SS Gas range
General Electric JGS905SEK3SS Gas range
General Electric JGS905TEK1WW Gas range
General Electric JGS905TEK2WW Gas range
General Electric JGS905TEK3WW Gas range
General Electric JGS968BEK1BB Gas range
General Electric JGS968BEK2BB Gas range
General Electric JGS968BEK3BB Gas range
General Electric JGS968BEK4BB GAS RANGE
General Electric JGS968BH1BB Gas range
General Electric JGS968BH2BB Gas range
General Electric JGS968BH3BB Gas range
General Electric JGS968BH4BB Gas range
General Electric JGS968BH5BB Gas range
General Electric JGS968BH6BB Gas range
General Electric JGS968KEK1CC Gas range
General Electric JGS968KEK2CC Gas range
General Electric JGS968KEK3CC Gas range
General Electric JGS968KEK4CC GAS RANGE
General Electric JGS968KH1CC Gas range
General Electric JGS968KH2CC Gas range
General Electric JGS968KH3CC Gas range
General Electric JGS968KH4CC Gas range
General Electric JGS968KH5CC Gas range
General Electric JGS968KH6CC Gas range
General Electric JGS968SEK1SS Gas range
General Electric JGS968SEK2SS Gas range
General Electric JGS968SEK3SS Gas range
General Electric JGS968SEK4SS GAS RANGE
General Electric JGS968SH1SS Gas range
General Electric JGS968SH2SS Gas range
General Electric JGS968SH3SS Gas range
General Electric JGS968SH4SS Gas range
General Electric JGS968SH5SS Gas range
General Electric JGS968SH6SS Gas range
General Electric JGS968TEK1WW Gas range
General Electric JGS968TEK2WW Gas range
General Electric JGS968TEK3WW Gas range
General Electric JGS968TEK4WW GAS RANGE
General Electric JGS968TH1WW Gas range
General Electric JGS968TH2WW Gas range
General Electric JGS968TH3WW Gas range
General Electric JGS968TH4WW Gas range
General Electric JGS968TH5WW Gas range
General Electric JGS968TH6WW Gas range
Jenn-Air JGS9900BDB RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDB15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDF RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDF15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDS RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDS15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900BDS16 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDB00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDF00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDR00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS01 30" SLIDE IN GAS ON GLASS DOWNDRAFT RANGE
Jenn-Air JGS9900CDS02 30" SLIDE-IN GAS ON GLASS DOWNDRAFT RANGE
General Electric JGSC07GEJ1 Electric range
General Electric JGSC07GEJ2 Gas range
General Electric JGSC08GEK1 Electric range
General Electric JGSC08GEK3 Electric range
General Electric JGSC12GEP1 Gas range
General Electric JGSC12GER1BG Gas range
General Electric JGSC12GET1BG Gas range
General Electric JGSC12GEV1BG Gas range
General Electric JGSP10GEK1 Electric range
General Electric JGSP10GEK2 Gas range
General Electric JGSP10GEK3 Electric range
General Electric JGSP20GEP1 Electric range
General Electric JGSP20GEP2 Gas range
General Electric JGSP20GER1BG Gas range
General Electric JGSP20GER2BG Gas range
General Electric JGSP20GER3BG Gas range
General Electric JGSP20GET1BB Gas range
General Electric JGSP21GEP1 Gas range
  #2 (permalink)
Old 02-05-2013, 10:02 AM
Junior Member
Default
ANSWER to my own question:
The wires were burnt because I did not properly install the last igniter six years ago. To do the job properly you must have access to the rear of the oven and remove the rear cover sheet metal! The 6 inch long high temperature white wires that are part of the igniter MUST go all the way straight through both openings in the sheet metal (two panels separated by an insulation zone). Then you can make the ceramic wire nut connections to the low temperature orange wires at the rear of the oven. Without access to the rear of the oven there is no way to guarantee that the low temp wires won't get stuck inside that hot insulation zone and melt. Removing the oven to access the rear was not too difficult, just awkward.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burnt igniter jtjackrabbit Dryer Repair 4 02-25-2012 10:30 PM
Burnt igniter wire connector PattiG Oven Repair (including Ranges and Cooktops) 0 09-08-2011 04:16 PM
Oven igniter/gas valve wiring comfort077 Oven Repair (including Ranges and Cooktops) 0 06-15-2011 11:44 AM
oven baking element wiring burnt out BobOscar Oven Repair (including Ranges and Cooktops) 6 12-15-2009 01:11 PM
maytag oven igniter to gas valve wiring braddowning Oven Repair (including Ranges and Cooktops) 0 12-02-2009 06:18 PM
