Discuss
Maytag Stove/Oven - oven will not turn off
 in
We replaced our heating element and when we restored power, the oven heated up without us turning on the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Stove/Oven - oven will not turn off
  #1 (permalink)
Old 09-29-2009, 05:23 PM
Junior Member
bodnarja is on a distinguished road
Default Maytag Stove/Oven - oven will not turn off
Brand: Maytag   Age: 5 - 10 years
We replaced our heating element and when we restored power, the oven heated up without us turning on the oven and we could not control the temp. We unplugged ion fear of burning out the new heating element. Please give us advise.
annie
Ads By Google
  #2 (permalink)
Old 09-30-2009, 05:54 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A Model Number may help others help you.
__________________
  #3 (permalink)
Old 10-09-2009, 06:28 AM
Junior Member
Default
Quote:
Thanks - the model number is MER5770AAA. OUr Maytag stove/oven has been out for 5 weeks - any tips would be great. Thanksgiving is coming!!!
  #4 (permalink)
Old 10-09-2009, 06:29 AM
Junior Member
Default
MOdel MER5770AAA in regards to the replaced heating element oven issue. Please help
  #5 (permalink)
Old 10-09-2009, 06:55 AM
Senior Expert
APP Volunteer
Default
Wiring information replacement parts for MAYTAG MER5770AAA | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag...s/16010161.pdf
Check to see if the element is on high or is it on half way.
What I am thinking is that for some reason you are getting half the line to the element. This would put 120 volts on it and you could not regulate it.
Perhaps one of the mounting plates of if it has feet has continuity to the heating element when it should be isolated ( an open/ infinite ohms).
Another possibility would be that the relay on the control board has it's contacts welded together.
__________________
  #6 (permalink)
Old 10-31-2009, 08:11 AM
Junior Member
Default
Would that be expensive and how do we check for the control panel? We needc to decide to replace or attempt to repair on our own. The unit is 10 years old.
  #7 (permalink)
Old 11-01-2009, 02:23 AM
Senior Expert
APP Volunteer
Default
Control Panel is Item 2 in Section 2 $129.45
Safest way to check is:
Unplug the unit
Check the resistance of each side of the element to the frame.
Both sides should be open (infinite ohms)
If OK
Undo one of the wires going to the element.
Measure from that wire to L1
If your reading is not open (infinite ohms) then the bake element relay's contacts are welded together.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Stove Smells Like A Little Gas Inside Then I Turn It On The Oven Door Moves BOBBY ZEE Oven Repair (including Ranges and Cooktops) 0 01-19-2010 06:37 PM
Maytag Gemini Double Oven Stove Fixer15 Oven Repair (including Ranges and Cooktops) 0 01-15-2010 07:09 PM
Oven will not turn on, broiler works, stove top works caewart Oven Repair (including Ranges and Cooktops) 1 06-20-2009 05:25 AM
Kenmore Gas oven. Stove top lights, but oven and broiler wont diggn89 Oven Repair (including Ranges and Cooktops) 1 08-27-2008 06:43 PM
Bought used Maytag oven/micro, fan runs, oven wont...lol Squirrel Oven Repair (including Ranges and Cooktops) 0 05-12-2008 06:30 PM
