Discuss
oven
 in
Oven won't heat, stays on Lo. I replaced the igniter and no luck. It clearly glows but I dont hear
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven
  #1 (permalink)
Old 01-02-2013, 06:39 PM
Junior Member
federicokiki is on a distinguished road
Default oven
Model Number: kgsc308llss0   Brand: Kitchen Aid   Age: 5 - 10 years
Oven won't heat, stays on Lo. I replaced the igniter and no luck. It clearly glows but I dont hear any gas coming out. I found a forum on-line that had a person with the same exact problem on the same range. They replaced the microcomputer and that did not work. They mentioned a fuse/fuses, any ideas? The broiler and cooktop work fines.
Read more: Kitchen Aid Superba KGSC308LSS0 WON'T HEAT
http://forum.appliancepartspros.com
Ads By Google
Related Models
Whirlpool KGSC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KGSI901PBL00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PBL01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBL02 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBS00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PBS01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBS02 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PSS00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PWH00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PWH01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PWH02 30" Freestanding Gas Oven Convection
Whirlpool KGSK901SBL00 30" Slide - in Gas Oven
Whirlpool KGSK901SSS00 30" Slide - in Gas Oven
Whirlpool KGSK901SWH00 30" Slide - in Gas Oven
Whirlpool KGSO145E
Whirlpool KGSP145E
Whirlpool KGSS907SBL00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SBT00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SSS00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SWH00 30" Slide - in Gas Oven Convection
Whirlpool KGST300BAL0
Whirlpool KGST300BAL1
Whirlpool KGST300BAL2
Whirlpool KGST300BWH0
Whirlpool KGST300BWH1
Whirlpool KGST300BWH2
Whirlpool KGST300FAL0
Whirlpool KGST300FAL1
Whirlpool KGST300FAL2
Whirlpool KGST300FWH0
Whirlpool KGST300FWH1
Whirlpool KGST300FWH2
Whirlpool KGST300HBL6
Whirlpool KGST300HBL8
Whirlpool KGST300HBL9
Whirlpool KGST300HBT0
Whirlpool KGST300HBT2
Whirlpool KGST300HBT3
Whirlpool KGST300HBT4
Whirlpool KGST300HBT5
Whirlpool KGST300HBT6
Whirlpool KGST300HBT8
Whirlpool KGST300HBT9
Whirlpool KGST300HWH0
Whirlpool KGST300HWH2
Whirlpool KGST300HWH3
Whirlpool KGST300HWH4
Whirlpool KGST300HWH5
Whirlpool KGST300HWH6
Whirlpool KGST300HWH8
Whirlpool KGST300HWH9
Whirlpool KGST307BAL0
Whirlpool KGST307BAL1
Whirlpool KGST307BAL2
Whirlpool KGST307BBL0
Whirlpool KGST307BBL1
Whirlpool KGST307BBL2
Whirlpool KGST307BWH0
Whirlpool KGST307BWH1
Whirlpool KGST307BWH2
Whirlpool KGST307FAL0
Whirlpool KGST307FAL1
Whirlpool KGST307FBL0
Whirlpool KGST307FBL1
Whirlpool KGST307FWH0
Whirlpool KGST307FWH1
Whirlpool KGST307GAL0
Whirlpool KGST307GBL0
Whirlpool KGST307GBS0
Whirlpool KGST307GBT0
Whirlpool KGST307GWH0
Whirlpool KGST307HBL0
Whirlpool KGST307HBL2
Whirlpool KGST307HBL3
Whirlpool KGST307HBL4
Whirlpool KGST307HBL5
Whirlpool KGST307HBL6
Whirlpool KGST307HBL8
Whirlpool KGST307HBL9
Whirlpool KGST307HBS0
Whirlpool KGST307HBS1
Whirlpool KGST307HBS2
Whirlpool KGST307HBS3
Whirlpool KGST307HBS4
Whirlpool KGST307HBS5
Whirlpool KGST307HBS6
Whirlpool KGST307HBS8
Whirlpool KGST307HBS9
Whirlpool KGST307HBT0
Whirlpool KGST307HBT2
Whirlpool KGST307HBT3
Whirlpool KGST307HBT4
Whirlpool KGST307HBT5
Whirlpool KGST307HBT6
Whirlpool KGST307HBT8
Whirlpool KGST307HBT9
Whirlpool KGST307HWH0
Whirlpool KGST307HWH2
Whirlpool KGST307HWH3
Whirlpool KGST307HWH4
Whirlpool KGST307HWH5
Whirlpool KGST307HWH6
Whirlpool KGST307HWH8
Whirlpool KGST307HWH9
Amana KGT-591 Range - S/c S/i Ddraft Gas
Amana KGT-593 Range - S/c S/i Ddraft Gas
Amana KGT-693 Range - S/c S/i Ddraft Gas
Amana KGT341 Surface Unit - Gas
International KGU5700BS Ref - Sxs
International KGU57990KD Ref - SXS/I&W
International KGU5950BS Ref - Sxs
International KGU5955BS Ref - Sxs
International KGU6465BS Ref - SXS/I&W
International KGU6465BSW Ref - SXS/I&W
International KGU6650 Ref - SXS/I&W
International KGU6651 Ref - SXS/I&W
International KGU6655 Ref - SXS/I&W
International KGU66920 Ref - SXS/I&W
International KGU6695 Ref - SXS/I&W
International KGU66990 Ref - SXS/I&W
  #2 (permalink)
Old 01-03-2013, 04:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
If there is no gas flow with the new igniter then the problem is a bad gas safety valve.
- The gas valve assembly Part number: 9755424
Here are the breakdown diagrams and Parts for Whirlpool KGSC308LSS0 Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-01-2013, 07:56 PM
Junior Member
Default
Hello Gene,
I have received the gas valve assembly as described in the auction. After replacing the valve assembly, the stovetop works but the oven does not heat up. Any more ideas or suggestions?
  #4 (permalink)
Old 02-05-2013, 03:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is the oven on-off switch on the side of the pressure regulator. Make sure it is on.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
