Discuss
classic grille (slide -in) hotplates
 in
My mom has had this thing for ages. Just last week the front hotplate in one module failed to turn
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » classic grille (slide -in) hotplates
  #1 (permalink)
Old 02-03-2008, 12:49 PM
zeiggy zeiggy is offline
Junior Member
zeiggy is on a distinguished road
Default classic grille (slide -in) hotplates
Model Number: 911-4698814   Brand: Kenmore   Age: More than 10 years
My mom has had this thing for ages. Just last week the front hotplate in one module failed to turn on, so I'm looking at it this weekend. there's a fair amount of "gunk" where the module plugs into the range.
Any tips on troubleshooting a module? Is it possible that it would just need a cleaning? Or do both plates on the module use the same electrical?
Thanks heaps!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 12:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Are the terminals on the cartridge burned or they are just greasy?
If they are not damaged then just clean them (do not forget to turn off the circuit breaker).
Remove the cartridge, take it apart and check both heating elements for continuity (Here are the complete instructions How To Check Continuity With Ohmmeter ).
- The part number for the large heating element is AP2027820
- The part number for the small heating element is AP2027821
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-05-2008, 09:14 PM
Junior Member
Default
they were greasy and the cleaning worked. Thanks for the link I'll keep it around in case this happens again.
  #4 (permalink)
Old 02-05-2008, 09:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
classic grille, oven not working RT41 Oven Repair (including Ranges and Cooktops) 2 01-10-2008 04:57 PM
Roper slide in gas range oven problem dankodrum Oven Repair (including Ranges and Cooktops) 0 12-13-2007 12:01 PM
Grille Removal Libbilu Refrigerator & Freezer Repair 1 11-27-2007 06:19 PM
Kenmore 30" electric self-cleaning slide in range dennisjane Oven Repair (including Ranges and Cooktops) 0 11-21-2007 03:18 AM
Ceramic Cooktop slide-in oven/stove EVdelRsoario Oven Repair (including Ranges and Cooktops) 1 09-19-2007 01:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
