Discuss
Gas Oven problem
 in
I have a Kenmore oven that appears to be experiencing a problem. When I turn the oven on bake, the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Oven problem
  #1 (permalink)
Old 09-29-2009, 02:59 PM
kwinn kwinn is offline
Junior Member
kwinn is on a distinguished road
Default Gas Oven problem
Model Number: 317B6034   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore oven that appears to be experiencing a problem. When I turn the oven on bake, the heating element will light and the gas will flow through the tube. Once the flame starts, you can hear the gas flowing to the burner. This is when the problem starts. The flame begins to pulsate as if the gas is not continueously flowing. the flame seems to be sputtering.
I turned the bottom element off of bake and set the oven to broil. Everything appears to be working fine when in this setting.
I did check to see if any of the flame holes were blocked. They all appear to be open.
Related Models
Magic Chef 3187VRA Range - F/s Std Gas
Magic Chef 3187VRV Range - F/s Std Gas
Magic Chef 3187VTA Range - F/s Std Gas
Magic Chef 3187VTV Range - F/s Std Gas
Magic Chef 3187VUA Range - F/s Std Gas
Magic Chef 3187VUV Range - F/s Std Gas
Magic Chef 3187XRA Range - F/s Std Gas
Magic Chef 3187XRW Range - F/s Std Gas
Magic Chef 3187XTA Range - F/s Std Gas
Magic Chef 3187XTW Range - F/s Std Gas
Magic Chef 3187XUA Range - F/s Std Gas
Magic Chef 3187XUW Range - F/s Std Gas
Magic Chef 31F-8KX-OC Range - F/s Std Gas
Magic Chef 31F6-7K Range - F/s Std Gas
Magic Chef 31FA-1 Range - F/s Std Gas
Magic Chef 31FA-10 Range - F/s Std Gas
Magic Chef 31FA-10-FJ Range - F/s Std Gas
Magic Chef 31FA-10K Range - F/s Std Gas
Magic Chef 31FA-10K-49 Range - F/s Std Gas
Magic Chef 31FA-10K-FJ Range - F/s Std Gas
Magic Chef 31FA-10KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-10KLXS-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-10KXS-ON Range - F/s Std Gas
Magic Chef 31FA-10XS-ON Range - F/s Std Gas
Magic Chef 31FA-11KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-11KW Range - F/s Std Gas
Magic Chef 31FA-11KX-ON Range - F/s Std Gas
Magic Chef 31FA-11KXS-ON Range - F/s Std Gas
Magic Chef 31FA-1K Range - F/s Std Gas
Magic Chef 31FA-1KLXS-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-1KXS-ON Range - F/s Std Gas
Magic Chef 31FA-1XS-EL Range - F/s Std Gas
Magic Chef 31FA-1XS-ON Range - F/s Std Gas
Magic Chef 31FA-2KLX Range - F/s Cont Clean Gas
Magic Chef 31FA-2KLX-CI Range - F/s Cont Clean Gas
Magic Chef 31FA-2KLX-NK Range - F/s Cont Clean Gas
Magic Chef 31FA-2KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-2KW-30 Range - F/s Std Gas
Magic Chef 31FA-2KWZ Range - F/s Std Gas
Magic Chef 31FA-2KX Range - F/s Std Gas
Magic Chef 31FA-2KX-ON Range - F/s Std Gas
Magic Chef 31FA-2KXS-EL Range - F/s Std Gas
Magic Chef 31FA-2KXS-ON Range - F/s Std Gas
Magic Chef 31FA-2LNW-A0 Range - F/s Cont Clean Gas
Magic Chef 31FA-2LNW-AD Range - F/s Cont Clean Gas
Magic Chef 31FA-2W Range - F/s Std Gas
Magic Chef 31FA-2W-AD Range - F/s Std Gas
Magic Chef 31FA-2W-QF Range - F/s Std Gas
Magic Chef 31FA-2X Range - F/s Std Gas
Magic Chef 31FA-2X-EC Range - F/s Std Gas
Magic Chef 31FA-2X-ON Range - F/s Std Gas
Magic Chef 31FA-2XS-ON Range - F/s Std Gas
Magic Chef 31FA-3KLV Range - F/s Cont Clean Gas
Magic Chef 31FA-3KLW Range - F/s Cont Clean Gas
Magic Chef 31FA-3KLX Range - F/s Cont Clean Gas
Magic Chef 31FA-3KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-3KV Range - F/s Std Gas
Magic Chef 31FA-3KW Range - F/s Std Gas
Magic Chef 31FA-3KX Range - F/s Std Gas
Magic Chef 31FA-3W Range - F/s Std Gas
Magic Chef 31FA-3X-ON Range - F/s Std Gas
Magic Chef 31FA-7 Range - F/s Std Gas
Magic Chef 31FA-7-02 Range - F/s Std Gas
Magic Chef 31FA-7-CN Range - F/s Std Gas
Magic Chef 31FA-7-EU Range - F/s Std Gas
Magic Chef 31FA-7-EW Range - F/s Std Gas
Magic Chef 31FA-7-NK Range - F/s Std Gas
Magic Chef 31FA-7EW Range - F/s Std Gas
Magic Chef 31FA-7K Range - F/s Std Gas
Magic Chef 31FA-7K-02 Range - F/s Std Gas
Magic Chef 31FA-7K-EW Range - F/s Std Gas
Magic Chef 31FA-7K-NK Range - F/s Std Gas
Magic Chef 31FA-7KW Range - F/s Std Gas
Magic Chef 31FA-7KX Range - F/s Std Gas
Magic Chef 31FA-7KXS-BB Range - F/s Std Gas
Magic Chef 31FA-7KXS-EH Range - F/s Std Gas
Magic Chef 31FA-7KXS-ON Range - F/s Std Gas
Magic Chef 31FA-7LW Range - F/s Cont Clean Gas
Magic Chef 31FA-7W Range - F/s Std Gas
Magic Chef 31FA-7X Range - F/s Std Gas
Magic Chef 31FA-7XS-BB Range - F/s Std Gas
Magic Chef 31FA-7XS-ON Range - F/s Std Gas
Magic Chef 31FA-8KLW Range - F/s Cont Clean Gas
Magic Chef 31FA-8KLW-02 Range - F/s Cont Clean Gas
Magic Chef 31FA-8KLX-OC Range - F/s Cont Clean Gas
Magic Chef 31FA-8KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-8KW Range - F/s Std Gas
Magic Chef 31FA-8KW-02 Range - F/s Std Gas
Magic Chef 31FA-8KW-CZ Range - F/s Std Gas
Magic Chef 31FA-8KW02 Range - F/s Std Gas
Magic Chef 31FA-8KX-EL Range - F/s Std Gas
Magic Chef 31FA-8KX-ES Range - F/s Std Gas
Magic Chef 31FA-8KX-OC Range - F/s Std Gas
Magic Chef 31FA-8KXS-CG Range - F/s Std Gas
Magic Chef 31FA-8KXS-ON Range - F/s Std Gas
Magic Chef 31FA-8LW Range - F/s Cont Clean Gas
Magic Chef 31FA-8LW-02 Range - F/s Cont Clean Gas
Magic Chef 31FA-8LX-CV Range - F/s Cont Clean Gas
Magic Chef 31FA-8LX-OC Range - F/s Cont Clean Gas
Magic Chef 31FA-8LX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-8W Range - F/s Std Gas
Magic Chef 31FA-8W-02 Range - F/s Std Gas
Magic Chef 31FA-8X-EL Range - F/s Std Gas
Magic Chef 31FA-8X-ES Range - F/s Std Gas
Magic Chef 31FA-8X-OC Range - F/s Std Gas
Magic Chef 31FA-8X-ON Range - F/s Std Gas
Magic Chef 31FA-92KLW Range - F/s Cont Clean Gas
Magic Chef 31FA-92KLX-EH Range - F/s Cont Clean Gas
Magic Chef 31FA-92KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-92KW Range - F/s Std Gas
Magic Chef 31FA-92KW-OJ Range - F/s Std Gas
Magic Chef 31FA-92KW-QJ Range - F/s Std Gas
Magic Chef 31FA-92KX-ON Range - F/s Std Gas
Magic Chef 31FA-92KXS-CG Range - F/s Std Gas
Magic Chef 31FA-92KXS-EL Range - F/s Std Gas
Magic Chef 31FA-92KXS-ON Range - F/s Std Gas
Magic Chef 31FA-92LW Range - F/s Cont Clean Gas
Magic Chef 31FA-92LX-EH Range - F/s Cont Clean Gas
Magic Chef 31FA-92LX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-92W Range - F/s Std Gas
  #2 (permalink)
Old 09-30-2009, 03:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The model number you posted does not come up. Verify and repost it.
__________________
  #3 (permalink)
Old 10-01-2009, 10:07 AM
Junior Member
Default Model Number
Quote:
Kenmore Modle #362.75876691 ser#8f228304p
Could it be the Pressure regulator or the the gas value. There is no problem with the Broiler or the top burners, just the bottom of the oven. It sounds as if the gas is not flowing continuously to the bottom burner.
  #4 (permalink)
Old 10-01-2009, 05:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the problem is a bad gas safety valve while there is a very small chance for the Bake igniter to cause such problem as well.
- The gas safety valve Part number: AP2022753
__________________
  #5 (permalink)
Old 10-02-2009, 06:37 AM
Junior Member
Default
Thank You. I off to the parts store.
  #6 (permalink)
Old 10-02-2009, 01:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 01-10-2010, 04:33 PM
xorg xorg is offline
Junior Member
xorg is on a distinguished road
Default
hello, just wanted to know if it was the gas safety valve? i have the same model with the exact same problem. the valve is over 150.00 and if it means i just scrap the range and buy new that would be fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven problem Shag Oven Repair (including Ranges and Cooktops) 1 02-07-2009 09:16 PM
ge oven not working. Oven door lock problem? Deano1 Oven Repair (including Ranges and Cooktops) 6 11-10-2008 01:02 PM
oven problem pinecone Oven Repair (including Ranges and Cooktops) 0 04-18-2008 07:37 AM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
Oven problem craigjung Oven Repair (including Ranges and Cooktops) 8 01-10-2008 02:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
