Discuss
GE Electric Oven F3 and F2 Error Code
 in
I have been getting F3 and F2 error codes out of my GE Electric Oven for years. I finally figured
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Electric Oven F3 and F2 Error Code
  #1 (permalink)
Old 01-02-2013, 11:04 AM
Junior Member
AnotherBrian is on a distinguished road
Default GE Electric Oven F3 and F2 Error Code
Model Number: JKP15AV1AA   Brand: GE   Age: 5 - 10 years
I have been getting F3 and F2 error codes out of my GE Electric Oven for years. I finally figured it out and here is the fix. Symptoms were that F3 or F2 error code would get set after the unit had been on for a while. Its a simple fix. I'm posting this because there are many posts on this forum attempting to deal with the problem.
Please refer to the attached photo showing the faulty soldering joint on the circuit board of the oven controller. The arrows point to the posts for the thermometer wires. I melted the two existing solder joints and added a little more solder using a small soldering iron (17watts).
Obviously you need to remove the oven from the power supply. Remove the top cover. There is a plastic ribbon to the oven controller that I removed. (That is the only cable I removed - no others are needed. The reason I removed it was because I didn't want it to bend, thus possibly breaking a brittle part.) To remove it, squeeze the tabs. Then it slides out. There are four screws holding the controller to the front panel. Remove those. Now the controller is accessible. There are tabs that hold the plastic cover that goes between the front panel and controller. Squeeze them and the plastic cover comes off. There are two plastic covers that go around the two circuit boards. Remove the top one. Now you see what you see in the photo and it is as easy as letting the significant other bake an apple pie!
Ads By Google
Related Models
General Electric JKP15AV1AA Electric range
General Electric JKP15AW1AA Electric range
General Electric JKP15AW2AA Electric range
General Electric JKP15BA1BB Electric range
General Electric JKP15BA2BB Electric range
General Electric JKP15BA3BB Electric range
General Electric JKP15BD1BB Electric range
General Electric JKP15BW1BB Electric range
General Electric JKP15BW2BB Electric range
General Electric JKP15CD1CC Electric range
General Electric JKP15WA1WW Electric range
General Electric JKP15WA2WW Electric range
General Electric JKP15WA3WW Electric range
General Electric JKP15WD1WW Electric range
General Electric JKP15WW1WW Electric range
General Electric JKP15WW2WW Electric range
General Electric JKP16G*07 Electric range
General Electric JKP16G*D1 Electric range
General Electric JKP16G*D2 GE BUILT-IN OVENS, CONVE
General Electric JKP16G*H1 Electric range
General Electric JKP16G*J1 Electric range
General Electric JKP16G*J2 Electric range
General Electric JKP16G*J3 Electric range
General Electric JKP16G*J4 Electric range
General Electric JKP16G*J5 Electric range
General Electric JKP16G*J6 Electric range
General Electric JKP16G0J3 ELECTRIC BUILT-IN OVEN
General Electric JKP16GJ4 ELECTRIC WALL OVEN
General Electric JKP16GJ5 ELECTRIC WALL OVEN
General Electric JKP16GJ6 ELECTRIC WALL OVEN
General Electric JKP16GP1BG Electric range
General Electric JKP16GP2BG Electric range
General Electric JKP16GP3BG Electric range
General Electric JKP16GP4BG Electric range
General Electric JKP16GPI ELECTRIC WALL OVEN
General Electric JKP16GT1BB Electric range
General Electric JKP16GT2BB Electric range
General Electric JKP16GV1BB Electric range
General Electric JKP17WP1WG Electric range
General Electric JKP17WP2WG Electric range
General Electric JKP17WP3WG Electric range
General Electric JKP17WPI ELECTRIC WALL OVEN
General Electric JKP17WT1WW Electric range
General Electric JKP17WT2WW Electric range
General Electric JKP17WV1WW Electric range
General Electric JKP18AA1AA Electric range
General Electric JKP18AA2AA Electric range
General Electric JKP18AA3AA Electric range
General Electric JKP18AS1AA Electric range
General Electric JKP18AT1AA Electric range
General Electric JKP18AT2AA Electric range
General Electric JKP18AV1AA Electric range
General Electric JKP18AW1AA Electric range
General Electric JKP18AW2AA Electric range
General Electric JKP18BA1BB Electric range
General Electric JKP18BA2BB Electric range
General Electric JKP18BA3BB Electric range
General Electric JKP18BD1BB Electric range
General Electric JKP18BW1BB Electric range
General Electric JKP18BW2BB Electric range
General Electric JKP18CD1CC Electric range
General Electric JKP18G*K1 Electric range
General Electric JKP18G*K2 Electric range
General Electric JKP18G*K3 Electric range
General Electric JKP18G*K4 Electric range
General Electric JKP18SD1SS Electric range
General Electric JKP18WA1WW Electric range
General Electric JKP18WA2WW Electric range
General Electric JKP18WA3WW Electric range
General Electric JKP18WD1WW Electric range
General Electric JKP18WW1WW Electric range
General Electric JKP18WW2WW ELECTRIC WALL OVEN
General Electric JKP19G*K1 Electric range
General Electric JKP19G*K2 Electric range
General Electric JKP19G*K3 Electric range
General Electric JKP19G*K4 Electric range
General Electric JKP20BF1BB Electric range
General Electric JKP20BF2BB Electric range
General Electric JKP20BF3BB Electric range
General Electric JKP20BF4BB Electric range
General Electric JKP20BF5BB Electric range
General Electric JKP20BF6BB Electric range
General Electric JKP20CF1CC Electric range
General Electric JKP20CF2CC Electric range
General Electric JKP20CF3CC Electric range
General Electric JKP20CF4CC Electric range
General Electric JKP20CF5CC Electric range
General Electric JKP20CF6CC Electric range
General Electric JKP20WF1WW Electric range
General Electric JKP20WF2WW Electric range
General Electric JKP20WF3WW Electric range
General Electric JKP20WF4WW Electric range
General Electric JKP20WF5WW Electric range
General Electric JKP20WF6WW Electric range
General Electric JKP25SH1SS Electric range
General Electric JKP25SH2SS Electric range
General Electric JKP25SH3SS Electric range
General Electric JKP25SH4SS Electric range
General Electric JKP25SH5SS Electric range
General Electric JKP25SH6SS Electric range
General Electric JKP26GP1 Electric range
General Electric JKP26GP2BG Electric range
General Electric JKP26GP3BG Electric range
General Electric JKP26GP4BG Electric range
General Electric JKP26GT1BB Electric range
General Electric JKP26GV1BB Electric range
General Electric JKP27*08 Electric range
General Electric JKP27*D1 Electric range
General Electric JKP27*D2 GE ELEC B/I 27" W/M/W
General Electric JKP27*J1 Electric range
General Electric JKP27*J2 Electric range
General Electric JKP27*J3 Electric range
General Electric JKP27*J4 Electric range
General Electric JKP27*J5 Electric range
General Electric JKP27BA1BB Electric range
General Electric JKP27BA2BB Electric range
General Electric JKP27BA3BB Electric range
General Electric JKP27BD1BB Electric range
General Electric JKP27BW1BB Electric range
General Electric JKP27BW2BB Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric Range Error Code F10 MRolfes27 Oven Repair (including Ranges and Cooktops) 0 07-13-2010 10:38 AM
Whirlpool Calypso Electric Dryer - E1 error code kleverkn Dryer Repair 2 04-30-2010 04:17 PM
ge electric range f4 error code when heating oven terraglio Oven Repair (including Ranges and Cooktops) 0 06-23-2009 08:30 AM
electric oven - F-3 error code, still having problems AKT Oven Repair (including Ranges and Cooktops) 0 03-20-2008 10:10 AM
electric oven - F-3 error code AKT Oven Repair (including Ranges and Cooktops) 1 02-20-2008 03:02 PM
