I was cooking my Super bowl fare and went to check the stove and all was off. Hubby checked fuse box all fine. After pushing buttons on the contol panel finally got the error code F3. From the forum ,I realize it has to do with the 'Open oven temperature sensor'. Where can I locate the Check sensor harness and harness connector?
