Discuss
Welded relay and oven slow to heat up
 in
OK, I give up on finding or getting the tech sheet for this oven I'm hoping that may be some
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Welded relay and oven slow to heat up
  #1 (permalink)
Old 01-01-2013, 09:50 AM
Junior Member
BBQEd is on a distinguished road
Default Welded relay and oven slow to heat up
Model Number: KEDS200YBL0   Brand: Kitchen Aid   Age: More than 10 years
OK, I give up on finding or getting the tech sheet for this oven I'm hoping that may be some one has seen this and can lead me in the right direction. This all started when it took a long time for the oven to heat up. The first thing I noticed was the baking coil would not heat up red. I then checked the baking, broil, and temp sensor they all checked good. Then I found 120VAC missing on one side of the baking coil. I then traced that wire back to a relay on the control board. The relay has a white wire (neutral) on the NC, red wire (120VAC) on the NO, and a blue on the COM. The relays contact on the NC was welded so not letting the relay to switch 120V to the COM which goes to the baking coil which was missing. Then I bought a new relay and soldered it to the board. The baking coil lit up red and the oven was working properly for a few uses then it started the same thing again. Tried another relay same thing!! So I then replaced the control board and the baking coil lit up the oven was working properly for a few uses and started the same thing again. I'm guessing the relay is welded again on the new board. I have checked for voltage on the neutral wire at the relay and reads 0. Could something in the top burner section be feeding power back to this relay and causing it to weld? I'm stumped and have had this apart so much I'm wondering if my drawing of where the wires go to this relay are correct but the same thing happens from the beginning till now. HELP!!!!!!
Thanks and Happy New Year
Ads By Google
Related Models
Whirlpool KEDS200YBL0
Whirlpool KEDS200YBL1
Whirlpool KEDS200YBL2
Whirlpool KEDS200YWH0
Whirlpool KEDS200YWH1
Whirlpool KEDS200YWH2
Whirlpool KEDS207BAL0
Whirlpool KEDS207BAL1
Whirlpool KEDS207BBL0
Whirlpool KEDS207BBL1
Whirlpool KEDS207BWH0
Whirlpool KEDS207BWH1
Whirlpool KEDS207YAL0
Whirlpool KEDS207YAL1
Whirlpool KEDS207YAL2
Whirlpool KEDS207YBL0
Whirlpool KEDS207YBL1
Whirlpool KEDS207YBL2
Whirlpool KEDS207YWH0
Whirlpool KEDS207YWH1
Whirlpool KEDS207YWH2
Whirlpool KEDT105SBL0
Whirlpool KEDT105SBL1
Whirlpool KEDT105VAL0
Whirlpool KEDT105VAL1
Whirlpool KEDT105VAL2
Whirlpool KEDT105VAL3
Whirlpool KEDT105VBL0
Whirlpool KEDT105VBL1
Whirlpool KEDT105VBL2
Whirlpool KEDT105VBL3
Whirlpool KEDT105VWH0
Whirlpool KEDT105VWH1
Whirlpool KEDT105VWH2
Whirlpool KEDT105VWH3
Whirlpool KEDT105WAL0
Whirlpool KEDT105WAL1
Whirlpool KEDT105WBL0
Whirlpool KEDT105WBL1
Whirlpool KEDT105WWH0
Whirlpool KEDT105WWH1
Whirlpool KEDT207YAL0
Whirlpool KEDT207YAL1
Whirlpool KEDT207YBL0
Whirlpool KEDT207YBL1
Whirlpool KEDT207YWH0
Whirlpool KEDT207YWH1
Whirlpool KEES702SWB0
Whirlpool KEES702SWB1
Whirlpool KEES705SAB1
Whirlpool KEES705SWB0
Whirlpool KEES705SWB1
Kelvinator KEF355ASA Kelvinator/electric Range
Kelvinator KEF355ASB Kelvinator/electric Range
Kelvinator KEF355ASC Kelvinator/electric Range
Kelvinator KEF355ASD Kelvinator/electric Range
Kelvinator KEF355ASE Kelvinator/electric Range
Kelvinator KEF355ASF Kelvinator/electric Range
Kelvinator KEF355ASG Kelvinator/electric Range
Kelvinator KEF355ASH Kelvinator/electric Range
Kelvinator KEF355ASJ Kelvinator/electric Range
Kelvinator KEF355DSA Kelvinator/electric Range
Kelvinator KEF355DSB Kelvinator/range
Kelvinator KEF355DSC Kelvinator/range
Kelvinator KEF355ESC Kelvinator/range
Kelvinator KEF355ESD Kelvinator/range
Whirlpool KEHC309JBL0
Whirlpool KEHC309JBL05 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBL06 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBL07 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBL08 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBL2
Whirlpool KEHC309JBL3
Whirlpool KEHC309JBL4
Whirlpool KEHC309JBT0
Whirlpool KEHC309JBT05 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBT06 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBT07 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBT08 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JBT2
Whirlpool KEHC309JBT3
Whirlpool KEHC309JBT4
Whirlpool KEHC309JSS0
Whirlpool KEHC309JSS05 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JSS06 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JSS07 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JSS08 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JSS2
Whirlpool KEHC309JSS3
Whirlpool KEHC309JSS4
Whirlpool KEHC309JWH0
Whirlpool KEHC309JWH05 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JWH06 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JWH07 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JWH08 30" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC309JWH2
Whirlpool KEHC309JWH3
Whirlpool KEHC309JWH4
Whirlpool KEHC379JBL0
Whirlpool KEHC379JBL05 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBL06 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBL07 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBL08 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBL3
Whirlpool KEHC379JBL4
Whirlpool KEHC379JBT0
Whirlpool KEHC379JBT05 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBT06 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBT07 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBT08 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JBT3
Whirlpool KEHC379JBT4
Whirlpool KEHC379JSS0
Whirlpool KEHC379JSS05 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JSS06 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JSS07 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JSS08 27" Built - in Electric Double Oven Thermal Convection Lower Microwave Convection
Whirlpool KEHC379JSS3
Whirlpool KEHC379JSS4
Whirlpool KEHC379JWH0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven slow to heat father24 Oven Repair (including Ranges and Cooktops) 0 11-24-2010 09:41 AM
Oven is slow to pre-heat booger Oven Repair (including Ranges and Cooktops) 0 10-18-2009 07:42 PM
oven is slow to heat Tony B Oven Repair (including Ranges and Cooktops) 0 09-02-2009 05:45 PM
oven slow to heat up freanclr Oven Repair (including Ranges and Cooktops) 0 03-09-2009 12:43 PM
Oven slow to heat up ladbroke Oven Repair (including Ranges and Cooktops) 1 12-12-2007 11:09 AM
