Discuss
Another Whirlpool Autoclean Fail
 in
Now I'm starting to wonder if I got the oven sensors mixed up and put the one from the bad
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Another Whirlpool Autoclean Fail
  #11 (permalink)
Old 11-21-2013, 01:09 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Now I'm starting to wonder if I got the oven sensors mixed up and put the one from the bad oven back in.
Pull it and check it.
If it measures 1080 it is probably OK.
If OK then odds are that the control board is bad.
__________________
  #12 (permalink)
Old 11-21-2013, 02:40 PM
Junior Member
Appliancetard is on a distinguished road
Default
Is there anything else it could possibly be? Would it be worth having a repair man check it out? Also, if it is the control board, where do I find a new one or am I expected to replace the wall ovens?
Thanks again.
Update:
Okay, the reason I was getting error codes is because I didn't have both sensors connected at the same time. I switched the sensors and tested them again and they are both definitely good as the one from the bad oven when placed in the good oven worked fine.
So now I just need to know how to replace the board or if I should call a repair man because there may be a much cheaper break that I am not going to pick up on before I purchase the board, assuming I can replace the control board.
Also, what is a limit switch? A repair person told me to check that. I'm assuming it is just another term for the thermostat overload that I already replaced.
  #13 (permalink)
Old 11-22-2013, 01:59 AM
Senior Expert
APP Volunteer
Default
Yes it is. Also they are called thermal fuses.
Below is the control board.Note that AppliancePartsPros will let you return the board if it does not fix your problem. Most places will not accept electrical returns. Please see their return policy
Part number: AP5801413
__________________
  #14 (permalink)
Old 11-22-2013, 05:09 PM
Junior Member
Thumbs up
Quote:
Originally Posted by denman View Post
[color="Blue"]
Thank you for all of your help denman! This has been a great learning experience for me. It really is fun to fix things yourself (assuming you are able to fix it)
I will let you know if the board fixes it and thank you for linking to the part and letting me know about ApplianceParts return policy. It may be awhile before I order the part for lack of $, but I will let you know if it fixes the problem when I do.
  #15 (permalink)
Old 11-23-2013, 02:52 AM
Senior Expert
APP Volunteer
Default
You are welcome.
I will keep my fingers crossed that we have diagnosed it correctly.
__________________
  #16 (permalink)
Old 01-21-2014, 08:59 PM
Junior Member
Default
Okay, I have the control board and my oven is out of the wall, power off, and I can't figure out how the control panel comes off. I don't see any screws, so I'm assuming it just pops off, but don't want to break it. Any ideas?
  #17 (permalink)
Old 01-21-2014, 10:40 PM
Junior Member
Default
Figured it out. Wow, it's not the control board. Guess I'm calling a repair man.
  #18 (permalink)
Old 02-21-2014, 10:49 AM
Junior Member
Default
I had it all fixed. The repair guy said there was a loose fuse next to the control board causing the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven Door Hinges Continuously Fail togamac Oven Repair (including Ranges and Cooktops) 2 12-05-2012 09:18 AM
whirlpool accubake oven's START button fail (pics) openappliance Oven Repair (including Ranges and Cooktops) 0 09-18-2011 09:56 PM
Whirlpool Oven Failure after Power Fail cweaker Oven Repair (including Ranges and Cooktops) 2 05-14-2010 05:12 PM
Whirlpool gas oven/broiler fail GrueLurks Oven Repair (including Ranges and Cooktops) 7 05-25-2009 05:43 PM
Go to AutoClean no matter what I push deej1212 Dishwasher Repair 1 10-28-2008 03:01 PM
