Discuss
Maytag overhead oven control board
 in
The broiler isn't working, I ohm ed everything out , checked voltage to oven, checked breaker also all good .
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag overhead oven control board
  #1 (permalink)
Old 12-31-2012, 11:02 AM
Junior Member
onehotpny is on a distinguished road
Default Maytag overhead oven control board
Model Number: CWE4200ACB   Brand: Maytag   Age: 5 - 10 years
The broiler isn't working, I ohm ed everything out , checked voltage to oven, checked breaker also all good . I also checked elements, all ohm out ... before I removed oven control board I checked all connections, looked at wiring diagram . I notice that lower element would come on ,but broiler wouldn't,so I then turned power off and then switched the yellow wire on lower relay and put it on broiler relay, then turned power back on and lower element wouldn't come on,but broiler would then work, so after turning power back off,I then hooked everything back up the way it's suppose to be. still no broiler function so then I knew it's a faulty oven control board. I order the part 7601M320-60 from here , part comes, I change the board out and still no broiler function . So I look a little closer and notice the new board has a lose relay from bad solder. so i contact custom support and they send out another board, but this one came with out plastic cover,so i take cover off old board and put it on new one,then in stall the new board. still no broiler function. contact customer service and now I'm here. need help, this is a rental trailer and I need to get the oven back to working. It's hard to believe I received two bad oven control boards,but from what I can tell i have. side note, I have over 2rys electrical training,so this isn't my first repair on a stove/oven.
Please help.
James
Ads By Google
Related Models
Maytag CWE4200ACB Walloven - Std Ele
Maytag CWE450 Walloven - Std Ele
Maytag CWE451 Walloven - Std Ele
Maytag CWE470 Walloven - S/c Ele
Maytag CWE4700ACB Walloven - S/c Ele
Maytag CWE4700ACE Walloven - S/c Ele
Maytag CWE4700BCB Walloven - S/c Ele
Maytag CWE4700BCE Walloven - S/c Ele
Maytag CWE4800ACB Walloven - S/c Ele
Maytag CWE4800ACE Walloven - S/c Ele
Maytag CWE4800ACS Walloven - S/c Ele
Maytag CWE500 Walloven - Std Ele
Maytag CWE501 Walloven - Std Ele
Maytag CWE502 Walloven - Std Ele
Maytag CWE5020ACB Walloven - Std Ele
Maytag CWE5020BCB Walloven - Std Ele
Maytag CWE5200ACB Walloven - S/c Ele
Maytag CWE5200ACE Walloven - S/c Ele
Maytag CWE550 Walloven - S/c Ele
Maytag CWE5500ACB Walloven - S/c Ele
Maytag CWE5500ACE Walloven - S/c Ele
Maytag CWE5500BCB Walloven - S/c Ele
Maytag CWE5500BCE Walloven - S/c Ele
Maytag CWE5800ACB Walloven - S/c Ele
Maytag CWE5800ACE Walloven - S/c Ele
Maytag CWE5800ACS Walloven - S/c Ele
Maytag CWE600 Walloven - S/c Ele
Maytag CWE601 Walloven - S/c Ele
Maytag CWE602 Walloven - S/c Ele
Maytag CWE6020ACB Walloven - S/c Ele
Maytag CWE6200ACB Walloven - S/c Ele
Maytag CWE6200ACE Walloven - S/c Ele
Maytag CWE6200ADB Walloven - S/c Ele
Maytag CWE6200ADE Walloven - S/c Ele
Maytag CWE6230ACB Walloven - S/c Ele
Maytag CWE6230ACE Walloven - S/c Ele
Maytag CWE6230ADB Walloven - S/c Ele
Maytag CWE6230ADE Walloven - S/c Ele
Maytag CWE6800ACB Walloven - S/c Ele
Maytag CWE6800ACE Walloven - S/c Ele
Maytag CWE6830ACB Walloven - S/c Ele
Maytag CWE6830ACE Walloven - S/c Ele
Maytag CWE700 Walloven - S/c Ele
Maytag CWE7000ACB Walloven - S/c Ele
Maytag CWE7000ACE Walloven - S/c Ele
Maytag CWE701 Walloven - S/c Ele
Maytag CWE7800ACB Walloven - S/c Ele
Maytag CWE7800ACE Walloven - S/c Ele
Maytag CWE7830ACB Walloven - S/c Ele
Maytag CWE7830ACE Walloven - S/c Ele
Maytag CWE900 Walloven - S/c Ele
Maytag CWE9000ACB Walloven - S/c Ele
Maytag CWE9000ACE Walloven - S/c Ele
Maytag CWE9000BCB Walloven - S/c Ele
Maytag CWE9000BCE Walloven - S/c Ele
Maytag CWE9000BCM Walloven - S/c Ele
Maytag CWE9000BDB Walloven - S/c Ele
Maytag CWE9000BDE Walloven - S/c Ele
Maytag CWE9000CDB Walloven - S/c Ele
Maytag CWE9000CDE Walloven - S/c Ele
Maytag CWE9000DDB Walloven - S/c Ele
Maytag CWE9000DDE Walloven - S/c Ele
Maytag CWE9030BCB Walloven - S/c Ele
Maytag CWE9030BCE Walloven - S/c Ele
Maytag CWE9030BDB Walloven - S/c Ele
Maytag CWE9030BDE Walloven - S/c Ele
Maytag CWE9030DDB Walloven - S/c Ele
Maytag CWE9030DDE Walloven - S/c Ele
Maytag CWE9900 Walloven - S/c Ele
Admiral CWEA100ACB Walloven - Std Ele
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 Walloven - Std Gas
Maytag CWG301 Walloven - Std Gas
Maytag CWG302 Walloven - Std Gas
Maytag CWG3020AAB Walloven - Std Gas
Maytag CWG3020AAE Walloven - Std Gas
Maytag CWG3020BAB Walloven - Std Gas
Maytag CWG3020BAE Walloven - Std Gas
Maytag CWG3100AAB Walloven - Std Gas
Maytag CWG3100AAE Walloven - Std Gas
Maytag CWG3100AAS Walloven - Std Gas
Maytag CWG3100AAW Walloven - Std Gas
Maytag CWG351 Walloven - Std Gas
Maytag CWG3510AAB Walloven - Std Gas
Maytag CWG3510BAB Walloven - Std Gas
Maytag CWG3600AAB Walloven - Std Gas
Maytag CWG3600AAE Walloven - Std Gas
Maytag CWG3600AAQ Walloven - Std Gas
Maytag CWG3600AAS Walloven - Std Gas
Maytag CWG400 Walloven - Std Gas
Maytag CWG401 Walloven - Std Gas
Maytag CWG402 Walloven - Cont Clean Gas
Maytag CWG4020AAB Walloven - Cont Clean Gas
Maytag CWG4020BAB Walloven - Cont Clean Gas
Maytag CWG4100AAB Walloven - Std Gas
Maytag CWG450 Walloven - Std Gas
Maytag CWG451 Walloven - Cont Clean Gas
Maytag CWG4510AAB Walloven - Cont Clean Gas
Maytag CWG4510BAB Walloven - Cont Clean Gas
Maytag CWG4600AAB Walloven - Std Gas
Admiral CWGA200AAB Walloven - Cont Clean Gas
Admiral CWGA800AAB Walloven - S/c Gas
Admiral CWGA800AAE Walloven - S/c Gas
Whirlpool CWI1701W0
Whirlpool CWI1701W1
Whirlpool CWI2101W0
Whirlpool CWI2101W1
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
  #2 (permalink)
Old 12-31-2012, 11:04 AM
Junior Member
Default
This oven doesn't have the self cleaning feature. if that helps at all.
  #3 (permalink)
Old 12-31-2012, 04:13 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
According the wiring diagram if you are not getting 240VAC to the broil element it has to be the clock/control board.
Get another one.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 12-31-2012, 05:07 PM
Junior Member
Default
Hi, this oven only has one control board. the oven control board is one complete unit. there isn't any other electronic part on the oven. I can take picture of the inside of the unit if needed and also the back part of the outside where wires and all are located.
  #5 (permalink)
Old 12-31-2012, 05:12 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Get another one.
Simon.
Hi, wouldn't this be the same as the oven control board that I've already replaced and found to be bad? So could I be right that the part I replaced is a bad part?
  #6 (permalink)
Old 01-01-2013, 03:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Yes James. This is the same part and looks like the new part is defective again. I will forward it to the APP customer service and someone will contact you tomorrow.
Unfortunately we can not rely on new parts any more. Very sad.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #7 (permalink)
Old 01-01-2013, 04:23 PM
Junior Member
Default
Thanks Gene. Looks like Robert Shaw ( manufacturer of oven board) is slacking on their quality control. Thanks for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag control board connector type for control panel cable? damoappc Dishwasher Repair 4 12-03-2012 03:29 PM
Maytag MDB8951BWS (Control Panel VS Control Board) tommy.elliott Dishwasher Repair 5 06-12-2012 05:30 PM
Maytag - Oven not working - Control Board? datenshi Oven Repair (including Ranges and Cooktops) 5 05-18-2012 03:40 PM
Kenmore Built In Oven Control Panel And Oven Control Board. TDEUCEDOG06 Oven Repair (including Ranges and Cooktops) 0 06-01-2010 03:28 PM
