| » ERC board |
Model Number: ACF4255AW Brand: Amana Age: 5 - 10 years
I am having trouble with this stove not heating to desired temp. I found that the lower elements relay was not picking up after testing with meter. I removed this relay from board and tested with a 24vdc power supply and it was good. after further review looks a if a transistor is turning this on and off. I noticed that there is a smaller relay on board that turns the door locking latch on so I desided to swap is transistor with bottom heating elements one and now it turns on but will not shut off. Had oven turned to 350 and after a bit when first turning oven on it would shut off and than turn back on relay but went up to 450 and with no sign of shutting off. I figure transistor is still good because when I canceled oven the relay shut off. Question is does anyone have any other ideas or better a schematic of this stoves electrical system.
| Display Modes | |
| Control board or ciruit board | sepedro@comcast.net | Oven Repair (including Ranges and Cooktops) | 0 | 02-25-2012 12:29 PM |
| how to determine if I need a control board or a circut board | tschorr@myway.com | Dishwasher Repair | 0 | 11-06-2011 09:09 AM |
| High voltage surge damaged the control board,replaced board,compressor still not runn | shillion | Refrigerator & Freezer Repair | 0 | 11-16-2010 01:18 AM |
| Main Controller Board or Display Board? | slarson252 | Refrigerator & Freezer Repair | 0 | 05-08-2010 07:16 AM |
| Replacing circuit board but new board model is for dual heating elements | tinaott | Refrigerator & Freezer Repair | 1 | 10-15-2009 05:13 AM |
