Discuss
Oven not properly heating up.
 in
Temp will not rise more than about 275 degrees when set at 400. Put in new temp sensor, manually wedged
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not properly heating up.
  #1 (permalink)
Old 12-23-2012, 05:27 PM
Junior Member
GRLauer is on a distinguished road
Default Oven not properly heating up.
Model Number: 9114042991   Brand: Kenmore   Age: More than 10 years
Temp will not rise more than about 275 degrees when set at 400. Put in new temp sensor, manually wedged k2 relay gently with a piece of wood. Temp climbed to 400, and then removed piece of wood, contact open temp dropped, but would not come up again.
Relays all seem to be working, no error codes. Circuit board looks good as far as I can see as do the diodes and resistors. Everything seems to work good except for the temperature.
Does it sound like the control board should be replaced as the oven is 20 years old?
Thank you
Ads By Google
Related Models
Kenmore 9114042991 ELECTRIC BUILT-IN OVEN
Kenmore 9114042992 ELEC. BUILT-IN OVEN
Kenmore 9114042993 ELEC. BUILT-IN OVEN
Kenmore 9114042994 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114044590 FILLER KIT
Kenmore 9114044990 FILLER KIT
Kenmore 91140465690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140465791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140465792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140469690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140469791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140469792 24" ELECTRIC NUILT-IN OVEN
Kenmore 9114047590 FILLER KIT
Kenmore 9114047990 FILLER KIT
Kenmore 91140495890 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140495891 BUILT-IN DOUBLE OVEN
Kenmore 91140499890 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140499891 BUILT-IN DOUBLE OVEN
Kenmore 9114088816 ELECTRIC BUILT-IN OVEN
Kenmore 9114088896 ELECTRIC BUILT-IN OVEN
Kenmore 91141055590 Built-In Oven, Electric
Kenmore 91141055591 Built-In Oven, Electric
Kenmore 9114105590 30" ELECTRIC BUILT IN OVEN
Kenmore 91141059590 Free Standing, Electric
Kenmore 91141059591 Free Standing, Electric
Kenmore 9114105990 30" ELECTRIC BUILT IN OVEN
Kenmore 91141065690 Built-In Oven, Electric
Kenmore 91141065791 Built-In Oven, Electric
Kenmore 91141066790 Built-In Oven, Electric
Kenmore 91141069690 Built-In Oven, Electric
Kenmore 91141069791 Built-In Oven, Electric
Kenmore 91141084993 BUILT-IN ELECTRIC OVEN
Kenmore 91141084994 ELECTRIC BUILT-IN OVEN
Kenmore 91141085890 30" ELECTRIC BUILT-IN OVEN
Kenmore 91141085991 BUILT IN OVEN
Kenmore 91141085992 BUILT IN OVEN
Kenmore 91141085993 BUILT-IN ELECTRIC OVEN
Kenmore 91141085994 ELECTRIC BUILT-IN OVEN
Kenmore 91141086890 30" ELECTRIC BUILT-IN OVEN
Kenmore 91141086991 BUILT IN OVEN
Kenmore 91141086992 BUILT IN OVEN
Kenmore 91141086993 BUILT-IN ELECTRIC OVEN
Kenmore 91141086994 ELECTRIC BUILT-IN OVEN
Kenmore 91141089890 30" ELECTRIC BUILT-IN OVEN
Kenmore 91141089991 BUILT IN OVEN
Kenmore 91141089992 BUILT IN OVEN
Kenmore 91141089993 BUILT-IN ELECTRIC OVEN
Kenmore 91141089994 ELECTRIC BUILT-IN OVEN
Kenmore 91141155590 30" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 91141159590 30" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 91141165690 Built-In Oven, Electric
Kenmore 91141165791 30 WALL OVEN
Kenmore 91141169690 Built-In Oven, Electric
Kenmore 91141169791 30 WALL OVEN
Kenmore 91141184993 BUILT-IN DOUBLE OVEN
Kenmore 9114272591 ELECTRIC COOKTOP
Kenmore 9114272790 ELECTRIC COOKTOP
Kenmore 9114308090 ELECTRIC COOKTOP
Kenmore 9114308610 KENMORE BUILT-IN ELECRIC COUNTER UNIT
Kenmore 9114318610 KENMORE BUILT-IN ELECTRIC COUNTER UNIT
Kenmore 9114337910 KENMORE ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114337991 KENMORE ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114338590 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114338591 ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114338611 MODULAR COUNTER UNIT
Kenmore 9114338680 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114338690 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114342090 ELEC. COUNTER UNIT
Kenmore 9114342190 ELEC. COUNTER UNIT
Kenmore 91143474100 36" COUNTER UNIT
Kenmore 91143475890 36" COUNTER UNIT
Kenmore 91143476890 36" COUNTER UNIT
Kenmore 91143479890 36" COUNTER UNIT
Kenmore 9114348610 BUILT IN ELECTRIC COUNTER UNIT
Kenmore 9114348690 BUILT IN ELECTRIC COUNTER UNIT
Kenmore 9114352590 ELECTRIC COUNTER UNIT
Kenmore 9114352591 36" ELECTRIC COUNTER UNIT
Kenmore 9114352990 ELECTRIC COUNTER UNIT
Kenmore 91143559590 KENMORE 36" ELECTRIC COUNTER UNIT
Kenmore 9114358810 ELECTRIC COUNTER UNIT
Kenmore 91143612100 COOKTOP
Kenmore 91143617100 COOKTOP
Kenmore 91143619100 COOKTOP
Kenmore 9114364590 RADIANT COUNTER UNIT
Kenmore 9114364591 RADIANT COUNTER UNIT
Kenmore 9114364990 RADIANT COUNTER UNIT
Kenmore 9114364991 RADIANT COUNTER UNIT
Kenmore 91143675890 ELECTRIC RANGE
Kenmore 91143675991 36" RADIANT COUNTER UNIT
Kenmore 91143679890 36" RADIANT COUNTER UNIT
Kenmore 91143679991 36" RADIANT COUNTER UNIT
Kenmore 9114378680 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114378690 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114378892 BUILT-IN ELECTRIC COUNTER UNIT
Kenmore 9114388810 ELECTRIC COUNTER UNIT
Kenmore 9114388890 ELECTRIC COUNTER UNIT
Kenmore 9114392590 ELECTRIC COOKTOP
Kenmore 9114392990 KENMORE INDUCTION COOKTOP
Kenmore 9114398510 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114398512 ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114398590 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114398610 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114398611 MODULAR COUNTER UNIT
Kenmore 9114398680 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 9114398690 SEARS ELECTRIC MODULAR COUNTER UNIT
Kenmore 91144002990 30" RADIANT COUNTER UNIT
Kenmore 91144003990 30" RADIANT COUNTER UNIT
Kenmore 91144004990 30" RADIANT COUNTER UNIT
Kenmore 91144009990 30" RADIANT COUNTER UNIT
Kenmore 91144012990 30" COUNTER UNIT
Kenmore 91144013990 30" COUNTER UNIT
Kenmore 91144014990 30" COUNTER UNIT
Kenmore 91144019990 30" COUNTER UNIT
Kenmore 91144022100 30" RADIANT COUNTER UNIT
Kenmore 91144023100 30" RADIANT COUNTER UNIT
Kenmore 91144024100 30" RADIANT COUNTER UNIT
Kenmore 91144029100 30" RADIANT COUNTER UNIT
Kenmore 91144032100 36" RADIANT COUNTER UNIT
Kenmore 91144033100 36" RADIANT COUNTER UNIT
Kenmore 91144034100 36" RADIANT COUNTER UNIT
  #2 (permalink)
Old 12-24-2012, 05:02 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I could not find any tech info on this unit so have to do some guessig.
Also it looks like the timer/control board is no longer available.
Most ovens do not give an error when there is a bad relay.
But the relay is not working correctly if wedging it closed does get the unit hotter.
Does the unit come ready or does it stay in pre-heat?
If it comes ready then the problem may be in the oven sensor circuit.
Check where the sensor connects to the board and the tracks to the first component down the line for cracks etc.
If the unit stays in pre-heat then for some reason the relay is not closing. Check the tracks etc. to the relay coil.
Could be the relay coil is open.
Also could be that the electronics controlling the relay are shot.
Cold solder joint checks.
A cold solder joint is often a duller gray and may also have pin holes.
Sometimes if you gently wiggle the component you will see the component's leg move in the solder joint.
You may be able to see cracks across the copper trails on the back side of the board.
A magnifying glass come in handy when doing the above checks.
There are companies out there that repair obsolete timers just Google "appliance timer repair"
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not heating properly Teresakay Oven Repair (including Ranges and Cooktops) 0 12-05-2010 09:04 AM
Gas oven not heating properly wandanyb Oven Repair (including Ranges and Cooktops) 2 03-17-2010 05:56 PM
Oven not heating properly kdr818 Oven Repair (including Ranges and Cooktops) 0 02-03-2009 01:14 PM
oven not heating properly harry foy Oven Repair (including Ranges and Cooktops) 1 12-16-2008 08:39 AM
Oven not heating properly naholter Oven Repair (including Ranges and Cooktops) 2 12-13-2007 08:05 AM
