Discuss
Range blows out infinite switch
 in
I have an Amana Range ( stove top with oven below ) that has 4 burners. Two smaller ones and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Range blows out infinite switch
  #1 (permalink)
Old 12-22-2012, 12:26 PM
Junior Member
fixer_bill is on a distinguished road
Unhappy Range blows out infinite switch
Model Number: AER5715QAS   Brand: Amana   Age: 5 - 10 years
Two smaller ones and two larger ones( back left and front right). One of the larger burners was getting red hot as soon as I turned it on low. The model number label actually says this range is MayTag AER5715QAS. I turned off the power to the range and took the back cover off behind the burner knobs. I noted carefully how the infinite switch wires were connected. Then, I swapped the infinite switch for the other large burner with the one that was not working and the switch worked fine on the other burner. However, I manage to get a pair of wires reversed on the switch connected to the non working burner and blow out the switch when I turned it on. Crap! So I ordered a new switch and a new large burner, putting the switch wires on properly and replaced the burner. Then after powering, and turning on the burner again I blew out the infinite switch again. After powering it off and back on the clock on front and the other 3 burners are still working fine. Could there be something else shorted out causing the switch to blow out? I checked out the switches with a ohmmeter according to on-line instructions and they both seem to be bad
(also have burn marks were they sparked before they blew out ) . Could something now be wrong with the Electronic control board that the switch wires are connected to ? Please help !
Ads By Google
Related Models
Amana AER5715QAS Range - S/c F/s Ele
Amana AER5715QAW Range - S/c F/s Ele
Amana AER5715QCB Range - S/c F/s Ele
Amana AER5715QCS Range - S/c F/s Ele
Amana AER5715QCW Range - S/c F/s Ele
Amana AER5715RCB Range - S/c F/s Ele
Amana AER5715RCS Range - S/c F/s Ele
Amana AER5715RCW Range - S/c F/s Ele
Amana AER5722BAB Range - S/c F/s Ele
Amana AER5722BAQ Range - S/c F/s Ele
Amana AER5722BAS Range - S/c F/s Ele
Amana AER5722BAW Range - S/c F/s Ele
Amana AER5722CAS Range - S/c F/s Ele
Amana AER5725QAB Range - S/c F/s Ele
Amana AER5725QAF Range - S/c F/s Ele
Amana AER5725QAN Range - S/c F/s Ele
Amana AER5725QAQ Range - S/c F/s Ele
Amana AER5725QAS Range - S/c F/s Ele
Amana AER5725QAW Range - S/c F/s Ele
Amana AER5735QAB Range - S/c F/s Ele
Amana AER5735QAF Range - S/c F/s Ele
Amana AER5735QAN Range - S/c F/s Ele
Amana AER5735QAQ Range - S/c F/s Ele
Amana AER5735QAS Range - S/c F/s Ele
Amana AER5735QAW Range - S/c F/s Ele
Amana AER5815RCB Range - S/c F/s Ele
Amana AER5815RCS Range - S/c F/s Ele
Amana AER5815RCW Range - S/c F/s Ele
Amana AER5845QAB Range - F/s Std Ele
Amana AER5845QAF Range - F/s Std Ele
Amana AER5845QAN Range - F/s Std Ele
Amana AER5845QAS Range - F/s Std Ele
Amana AER5845RAB Range - S/c F/s Ele
Amana AER5845RAS Range - S/c F/s Ele
Amana AER5845RAW Range - S/c F/s Ele
Amana AES1350BAW Range - S/c S/i Ele
General Electric AES15DAV1 Room air conditioner
General Electric AES18DAM1 Room air conditioner
General Electric AES23DAR1 Room air conditioner
Amana AES3540BAW Range - S/c S/i Gas
Amana AES3760BAB Range - S/c S/i Ele
Amana AES3760BAQ Range - S/c S/i Ele
Amana AES3760BAS Range - S/c S/i Ele
Amana AES3760BAW Range - S/c S/i Ele
Amana AES3760BCB Range - F/s Std Ele
Amana AES3760BCS Range - F/s Std Ele
Amana AES3760BCW Range - F/s Std Ele
Amana AES5730BAB Range - S/c S/i Ele
Amana AES5730BAF Range - S/c S/i Ele
Amana AES5730BAN Range - S/c S/i Ele
Amana AES5730BAS Range - S/c S/i Ele
Amana AET-480 Range - S/c S/i Ddraft Gas
Amana AET-480A Range - S/c S/i Ddraft Gas
Amana AET-480B Range - S/c S/i Ddraft Gas
Amana AET-480C Range - S/c S/i Ddraft Gas
General Electric AET05LHW1 Room air conditioner
General Electric AET05LJG1 Room air conditioner
General Electric AET05LJS1 Room air conditioner
General Electric AET05LJW1 Room air conditioner
Amana AEU-516 Range - S/c S/i Ddraft Gas
Amana AEU-516A Range - S/c S/i Ddraft Gas
Amana AEU-516C Range - S/c S/i Ddraft Gas
Amana AEU-516D Range - S/c S/i Ddraft Gas
Amana AEU-516E Range - S/c S/i Ddraft Gas
Amana AEU-516F Range - S/c S/i Ddraft Gas
Amana AEU-516G Range - S/c S/i Ddraft Gas
General Electric AEV24DJH1 Room air conditioner
General Electric AEV24DKH1 Room air conditioner
General Electric AEW05LJG1 Room air conditioner
General Electric AEW05LJS1 Room air conditioner
General Electric AEW05LJW1 Room air conditioner
General Electric AEW06LJG1 Room air conditioner
General Electric AEW06LJS1 Room air conditioner
General Electric AEW08AJS1 Room air conditioner
General Electric AEW10AJG1 Room air conditioner
General Electric AEW10AJS1 Room air conditioner
General Electric AEW24DHH1 Room air conditioner
General Electric AEW24DJH1 Room air conditioner
General Electric AEW24DKH1 Room air conditioner
Amana AEW3530DDB Walloven - S/c Ele
Amana AEW3530DDS Walloven - S/c Ele
Amana AEW3530DDW Walloven - S/c Ele
Amana AEW3630DDB Walloven - S/c Dbl Oven Ele
Amana AEW3630DDS Walloven - S/c Dbl Oven Ele
Amana AEW3630DDW Walloven - S/c Dbl Oven Ele
Amana AEW4530DDB Walloven - S/c Ele
Amana AEW4530DDQ Walloven - S/c Ele
Amana AEW4530DDS Walloven - S/c Ele
Amana AEW4530DDW Walloven - S/c Ele
Amana AEW4630DDB Walloven - S/c Dbl Oven Ele
Amana AEW4630DDQ Walloven - S/c Dbl Oven Ele
Amana AEW4630DDS Walloven - S/c Dbl Oven Ele
Amana AEW4630DDW Walloven - S/c Dbl Oven Ele
General Electric AEX08FAM1 Room air conditioner
Jenn-Air AEX918 Misc / Accessory
Thermador AF-7M
General Electric AF108FMP1 Room air conditioner
General Electric AF112DMW1 Room air conditioner
Admiral AF122 Freezer - Vertical
General Electric AF615DPE1 Room air conditioner
General Electric AF615DSE1 Room air conditioner
General Electric AF615DTE1 Room air conditioner
General Electric AF715DME1 Room air conditioner
General Electric AF812DMW1 Room air conditioner
General Electric AF812DNW1 Room air conditioner
General Electric AF908FMP3 Room air conditioner
General Electric AF908FMP4 Room air conditioner
General Electric AF908FSP1 Room air conditioner
General Electric AF908FTP1 Room air conditioner
General Electric AF908FWP1 Room air conditioner
General Electric AF910MBT1 Room air conditioner
General Electric AF910MST1 Room air conditioner
General Electric AF912AMW3 Room air conditioner
General Electric AF912AMW4 Room air conditioner
General Electric AF912ANW1 Room air conditioner
General Electric AF912ASW1 Room air conditioner
General Electric AF912DMW2 Room air conditioner
General Electric AF912DPW1 Room air conditioner
General Electric AF912DSW1 Room air conditioner
General Electric AF912WAD3 Room air conditioner
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana electric range infinite switch limnidytis Oven Repair (including Ranges and Cooktops) 0 09-17-2011 12:54 PM
help removing control panel of range to replace infinite switch buddy90 Oven Repair (including Ranges and Cooktops) 0 01-08-2011 10:18 AM
infinite control switch for GE range JB960WB1WW tsimm Oven Repair (including Ranges and Cooktops) 0 03-06-2010 02:30 PM
Whirlpool Range Infinite Switch Ozzie33 Oven Repair (including Ranges and Cooktops) 0 09-05-2009 09:59 AM
Replacing Dual Infinite Switch on Range juchunk Oven Repair (including Ranges and Cooktops) 0 05-02-2008 07:51 AM
