| » GE JGRS14GEP1BG oven under heating |
Model Number: JGRS14GEP1BG Brand: GE Age: More than 10 years
Our JGRS14GEP1BG GE oven is not heating correct. Example. Set it to bake at 350, and it beeps that it is up to heat when the store bought thermometer is only reading about 200. At 400 setting, it is at about 325.
Took sensor out, checked with Ohm meter, and it was between 1080 and 1100. Cleaned sensor, and reinstalled (what a pain, not a plug in, but uses wire nuts/crimps) Igniter takes about 5 seconds to start glowing, then burner lights at about roughly 15 seconds from setting over temp. All holes in burner seem to be putting out flame. No error codes have ever popped up on control panel. When I put in a cookie sheet on second rack from highest, the thermometer, hanging under the cookie sheet does climb some. I've tried to read the forums and get an idea of what to check next, but I'm now stumped. Thanks so much for any ideas Ads By Google Related Models |
Hi.
Check the wire harness from the control board to the oven sensor, and if this is OK - replace the control board Part number: WB27T10327 Here are the breakdown diagrams and Control parts for GE JGRS14GEP1 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| The oven won't heat up. The pilot is lit and not heating oven | Hazelave.corp | Oven Repair (including Ranges and Cooktops) | 1 | 11-21-2012 10:23 PM |
| Oven door opens when in use causing oven to stop heating | puck | Oven Repair (including Ranges and Cooktops) | 3 | 03-14-2009 07:25 AM |
| Bottom heating element in oven not heating | Bill Pitts | Oven Repair (including Ranges and Cooktops) | 1 | 03-07-2009 06:02 PM |
| Frigidaire Double Oven/ Top oven not heating | dross3491 | Oven Repair (including Ranges and Cooktops) | 6 | 12-14-2008 12:33 PM |
| GE Wall Double Oven Top Oven Not Heating | ryoung | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2008 08:02 PM |
