| » how hard is it to replace electric glass top burner? |
Model Number: KECD866RBL01 Brand: Kitchen Aid Age: 5 - 10 years
The front left triple burner on the glass top downdraft cook top only heats on the largest size. What needs to be replaced and how hard is it to do this? Does the cook top need to be taken apart from underneath where the downdraft system is all connected?
Hello janis,
The problem can be a bad switch for this burner or a bad heating element. In order to determine which part exactly is bad you have to check both parts for continuity. In order to do it you have to remove the cooktop from the counter and take it apart from the bottom. I believe you can disconnect the blower unit from the cooktop before you will remove the cooktop from the counter. If you are willing to do the troubleshooting yourself, let us know and we will provide the troubleshooting instructions for you. If you do not feel comfortable to do it then hire a pro to do it for you. You still can by parts by yourself to save some money. - The infinite switch Part number: 8286070 - The heating element Part number: 8285846 Here are the breakdown diagrams and Parts for Whirlpool KECD866RBL01 Cooktop - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome. Remove the cooktop and take it apart. Start the troubleshooting from checking all wires and connections to make sure they are not grounded and/or shorted.
Draw a picture of how the wires are connected to the heating element and disconnect them. Check the heating element coils for continuity according to the wiring diagram attached to the post. If there is noting wrong, do the same with the infinite switch for this burner. Post the results. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter Gene.
__________________
| Display Modes | |
| Kitchenaid electric glass cooktop burner/contol | dmccollo | Oven Repair (including Ranges and Cooktops) | 3 | 03-04-2011 01:51 PM |
| How do i Open the Glass top to replace a burner element | Beverly h | Oven Repair (including Ranges and Cooktops) | 3 | 11-08-2010 08:50 AM |
| how to replace a burner on a kenmore glass top | djfoxylady | Oven Repair (including Ranges and Cooktops) | 0 | 10-23-2009 07:51 AM |
| wirlpool glass top electric oven burner | sting_ray08884 | Oven Repair (including Ranges and Cooktops) | 0 | 09-29-2008 07:29 AM |
| One burner is broken in Glass Top Electric Range | sval79 | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2007 12:03 PM |
