Discuss
Damaged Clear Cover on Metal Element Rod
 in
I ordered and received a new burner for an electric stove, Part numberAP3844901. When I went to install the element,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Damaged Clear Cover on Metal Element Rod
  #1 (permalink)
Old 12-18-2012, 05:23 PM
Junior Member
kkrater is on a distinguished road
Default Damaged Clear Cover on Metal Element Rod
Brand: Kenmore   Age: 5 - 10 years
I ordered and received a new burner for an electric stove, Part numberAP3844901. When I went to install the element, I noticed that the clearcovering on the metal rod that extends through the middle of the element wasslightly cracked/distressed along +/-1.5" of the rod length. Being thisclose to Christmas and needing the stove I made the decision to install theelement and it seems to be working fine. I just wanted to check with an expertand make sure that this is not a big deal (I'm guesssing that the metal rod isa thermostat?). Should I return this or do you think it will be OK?
Ads By Google
  #2 (permalink)
Old 12-20-2012, 10:43 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
This part of the heating element is a safety limiter which senses the temperature and cycling the heat on and off to prevent the glass from the overheating and breakage. I would recommend to exchange it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Visibly damaged heating element in Jenn-Air oven kyuss Oven Repair (including Ranges and Cooktops) 0 07-24-2011 09:07 PM
Do I insulate the metal terminals on an oven element? juvat Oven Repair (including Ranges and Cooktops) 3 03-07-2011 06:47 PM
Grinding sounding spin cycles, metal on metal redepta40 Washer Repair 3 06-21-2010 08:23 AM
whirlpool washer making metal on metal squealing on spin cycle LILHOOSIER22 Washer Repair 1 03-13-2009 04:29 PM
