Discuss
KitchenAid oven erratic heating
 in
Greetings, I have a KitchenAid drop in range/oven that will not maintain a constant temperature. For example, if I set
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » KitchenAid oven erratic heating
  #1 (permalink)
Old 12-18-2012, 03:43 PM
Junior Member
Norman G. is on a distinguished road
Default KitchenAid oven erratic heating
Model Number: KESC307HWW6   Brand: Kitchen Aid   Age: 5 - 10 years
Greetings,
I have a KitchenAid drop in range/oven that will not maintain a constant temperature. For example, if I set it to bake at 350, the chime will sound in a few minutes to indicate it is up to temp, the display will read 350, but in reality it is only 200 or so, according to an oven thermometer. I can then increase the temp to 450 and it will climb to more than 475. If I then lower it back to 350 it will drop back down to below 300.
I replaced the hidden bake element 2 years ago because it was bad, and it has worked fine until recently. Can someone please point me in the right direction?
Thanks,
Norman
Ads By Google
Related Models
Whirlpool KESC307HWW6
Whirlpool KESC307HWW8
Whirlpool KESC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KESH307BAL1
Whirlpool KESH307BAL2
Whirlpool KESH307BAL3
Whirlpool KESH307BAL4
Whirlpool KESH307BAL5
Whirlpool KESH307BAL6
Whirlpool KESH307BAL8
Whirlpool KESH307BAL9
Whirlpool KESH307BBL1
Whirlpool KESH307BBL2
Whirlpool KESH307BBL3
Whirlpool KESH307BBL4
Whirlpool KESH307BBL5
Whirlpool KESH307BBL6
Whirlpool KESH307BBL8
Whirlpool KESH307BBL9
Whirlpool KESH307BWH1
Whirlpool KESH307BWH2
Whirlpool KESH307BWH3
Whirlpool KESH307BWH4
Whirlpool KESH307BWH5
Whirlpool KESH307BWH6
Whirlpool KESH307BWH8
Whirlpool KESH307BWH9
Whirlpool KESH307GAL0
Whirlpool KESH307GAL1
Whirlpool KESH307GBL0
Whirlpool KESH307GBL1
Whirlpool KESH307GBS0
Whirlpool KESH307GBS1
Whirlpool KESH307GBT0
Whirlpool KESH307GBT1
Whirlpool KESH307GWH0
Whirlpool KESH307GWH1
Whirlpool KESH307HBL0
Whirlpool KESH307HBL1
Whirlpool KESH307HBL3
Whirlpool KESH307HBL4
Whirlpool KESH307HBL5
Whirlpool KESH307HBL6
Whirlpool KESH307HBS0
Whirlpool KESH307HBS1
Whirlpool KESH307HBS3
Whirlpool KESH307HBS4
Whirlpool KESH307HBS5
Whirlpool KESH307HBS6
Whirlpool KESH307HWH0
Whirlpool KESH307HWH1
Whirlpool KESH307HWH3
Whirlpool KESH307HWH4
Whirlpool KESH307HWH5
Whirlpool KESH307HWH6
Whirlpool KESI901PBL00 30" Slide - in Electric Oven
Whirlpool KESI901PBL01 30" Slide - in Electric Oven
Whirlpool KESI901PBS00 30" Slide - in Electric Oven
Whirlpool KESI901PBS01 30" Slide - in Electric Oven
Whirlpool KESI901PWH00 30" Slide - in Electric Oven
Whirlpool KESI901PWH01 30" Slide - in Electric Oven
Whirlpool KESK901SBL00 30" Slide - in Electric Oven
Whirlpool KESK901SSS00 30" Slide - in Electric Oven
Whirlpool KESK901SWH00 30" Slide - in Electric Oven
Whirlpool KESO140
Whirlpool KESO140S
Whirlpool KESO145
Whirlpool KESO145S
Whirlpool KESO170
Whirlpool KESO170S
Whirlpool KESO175
Whirlpool KESO175S
Whirlpool KESO176S
Whirlpool KESS300BAL0
Whirlpool KESS300BWH0
Whirlpool KESS907SBB00 30" Built - in Electric Oven
Whirlpool KESS907SBL00 30" Built - in Electric Oven
Whirlpool KESS907SSS00 30" Built - in Electric Oven
Whirlpool KESS907SWW00 30" Built - in Electric Oven
Whirlpool KESS908SPB00 30" Slide - in Electric Oven
Whirlpool KESS908SPS00 30" Slide - in Electric Oven
Whirlpool KESS908SPW00 30" Slide - in Electric Oven
Whirlpool KESV908PMT00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PMT01 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS01 30" Slide - in Electric Oven Convection
Amana KET-480 Range - S/c S/i Ddraft Gas
Amana KET-480A Range - S/c S/i Ddraft Gas
Amana KET-480B Range - S/c S/i Ddraft Gas
Amana KET-480C Range - S/c S/i Ddraft Gas
Amana KET570 Surface Unit - Ele
Amana KET590 Surface Unit - Ele
Amana KET595 Surface Unit - Ele
Amana KET700 Surface Unit - Ele
Whirlpool KEWD105HBL0
Whirlpool KEWD105HBL05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL1
Whirlpool KEWD105HBL3
Whirlpool KEWD105HBL4
Whirlpool KEWD105HBT0
Whirlpool KEWD105HBT05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBT06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBT1
Whirlpool KEWD105HBT3
Whirlpool KEWD105HBT4
Whirlpool KEWD105HSS0
Whirlpool KEWD105HSS05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HSS06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HSS1
Whirlpool KEWD105HSS3
Whirlpool KEWD105HSS4
Whirlpool KEWD105HWH0
Whirlpool KEWD105HWH05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HWH06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HWH1
Whirlpool KEWD105HWH3
Whirlpool KEWD105HWH4
Whirlpool KEWD175HBL0
Whirlpool KEWD175HBL05 27" Electric Built - in Warming Drawer
  #2 (permalink)
Old 12-18-2012, 07:51 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You should check the oven sensor and it's connector plug.
At room temperature the resistance should be about 1100ohm.
Replace if needed Part number: 9782081
If the sensor is OK - replace the control board
Part number: 9754383
Here are the breakdown diagrams and Control Panel parts for Whirlpool KESC307HWW6 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-19-2012, 04:45 AM
Junior Member
Default
Thank you for the fast reply. I will check in the next day or two and let you know what I find.
Thanks again,
Norman
  #4 (permalink)
Old 12-19-2012, 10:46 AM
Junior Member
Default
Ok, I checked resistance on the oven sensor and got a value of 1790 ohm (sensor was still mounted in oven chassis). Am I to assume this is too far out of spec and I need a new sensor? Please advise.
  #5 (permalink)
Old 12-19-2012, 11:27 AM
Expert
Default
Hi.
The resistance is way off. Can you describe, please how did you check it.Was it at room temperature?
Simon.
__________________
  #6 (permalink)
Old 12-19-2012, 01:43 PM
Junior Member
Default
Yes, at room temperature. Removed panel on rear of the range, isolated the sensor by unplugging it, set the meter at 2K ohms and plugged the test leads into the back side of the sensor plug. I did not remove the sensor from the range. Checked it several times and consistently got 1791 on the meter.
  #7 (permalink)
Old 12-19-2012, 01:57 PM
Expert
Default
Hi.
Get a new sensor.
Simon.
__________________
  #8 (permalink)
Old 12-20-2012, 01:46 PM
Junior Member
Default
Thank you, I have ordered a new sensor and will post the results when it arrives and I get it installed.
Thanks again.
Norman
  #9 (permalink)
Old 12-20-2012, 02:28 PM
Expert
Default
You are welcome.
Simon.
__________________
  #10 (permalink)
Old 12-22-2012, 01:04 PM
Junior Member
Default
New sensor arrived in only 2 days, but didn't seem to help.
Replaced the sensor, set to 350. In 20 minutes the oven only got to 325. Set it up to 450, 4 minutes later it had only reached 350, then 12 minutes after that, it finally got to 450. I tried setting it back down to 350 and in 15 minutes it was at 385, 15 minutes after that it was at 330. These temps are all checked by an oven thermometer, which I have no way of verifying, so it's hardly scientific.
I was really hoping the new sensor was the answer, but the original problem seems to remain. Any more ideas?
Thanks for your help.
Norman
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Erratic heating bake cycle in oven thang111 Oven Repair (including Ranges and Cooktops) 0 04-28-2012 02:36 PM
Kitchenaid Oven element not heating up kjk11 Oven Repair (including Ranges and Cooktops) 1 01-12-2012 01:07 PM
Kitchenaid oven not heating on bake msmith1234 Oven Repair (including Ranges and Cooktops) 7 11-17-2010 07:53 AM
Heating erratic e31430 Dryer Repair 0 11-12-2009 09:54 AM
Hotpoint electric Range erratic heating fixitman Oven Repair (including Ranges and Cooktops) 5 12-30-2008 06:06 AM
