Discuss
GE Oven heats above setting
 in
Oven preheats o.k. Then, I start baking food and in about 10mins I notice the heat has increased in oven.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven heats above setting
  #1 (permalink)
Old 12-18-2012, 11:21 AM
JAO JAO is offline
Junior Member
JAO is on a distinguished road
Default GE Oven heats above setting
Brand: GE   Age: 1 - 5 years
Oven preheats o.k. Then, I start baking food and in about 10mins I notice the heat has increased in oven. I'm using an oven thermometer so I know the heat is rising past the setting. Hence, I'm burning up everything in the oven. Talked w/ others and they said it was the control board malfunctioning. I wonder could this be related to the thermostat in any way too? Also, could I (a homemaker) replace the control board myself? Trying to save bucks but not burn down my house.
Ads By Google
  #2 (permalink)
Old 12-18-2012, 04:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the oven?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-19-2012, 02:50 AM
JAO JAO is offline
Junior Member
Default TO Gene
GE Model #
J BS55WOK4WW
  #4 (permalink)
Old 12-19-2012, 02:52 AM
JAO JAO is offline
Junior Member
Default
GE model #
J BS55WOK4WW
  #5 (permalink)
Old 12-19-2012, 02:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the difference between the set and real temperatures is within 35°F range then it can be adjusted.
If the difference is more than that, measure the oven temperature sensor resistance at the control board plug (terminals 1 & 2 at the five pins plug). The normal reading suppose to be about 1100 Ohms at the room temperature.
If the reading is incorrect, replace the oven temperature sensor.
If the reading is correct, replace the oven control board.
You can find the instructions in the attached mini-manual.
- The oven temperature sensor Part number: WB21T10007
- The oven control board Part number: WB27T11313
Here are the breakdown diagrams and Parts for GE JBS55WK4WW Range - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer only heats on moisture sensing cycle more dry setting jwilcoxen Dryer Repair 0 02-15-2012 08:51 PM
Thermador over heats up slow only if i keep moving setting anthony415 Oven Repair (including Ranges and Cooktops) 0 01-10-2012 06:19 PM
Whirlpool Gas Dryer. Heats but will not shut off if on auto dry miser setting tornado26 Dryer Repair 5 01-01-2012 09:43 AM
oven/range heats beyond setting denbeth Oven Repair (including Ranges and Cooktops) 3 11-10-2009 11:25 AM
Gas oven will not heat to setting darthrethaf005 Oven Repair (including Ranges and Cooktops) 1 06-12-2008 04:03 PM
