Gas Broiler Works On Low Only
I have a gas Bosch oven, model HGS235UC. The broiler lights but the flame seems low/weak & food seems to take a very long time to cook. Also, when I try to run the self clean cycle, the oven doesn't get up to temp.
Hello,
Measure the current drawn by the Broil igniter. If the reading is equal or less than 3.2 amps, replace the igniter. - The broil igniter Part number: 492429 Gene. |
Gene, I will do that. Thank you for the reply
Gene. |
| All times are GMT -7. The time now is 08:48 PM. |
