| » oven |
Model Number: jmw9527dab Brand: Jenn-Air Age: 1 - 5 years
Jenn-Air Model no: JMW 9527DAB This is a Microwave/Electric Wall Oven Combo. The microwave has power and works but the oven has no power If the unit is removed from wall there is a 20 amp reset on the back of the oven unit. I checked if ther was power to the reset and there is. I than bypassed the reset to see if the front touch panel would luminate. I still have no power to the oven. Can you help.
Related Models |
Here are your parts includes a wiring diagram.
Replacement parts for JENN-AIR JMW9527DAB | AppliancePartsPros.com Here is a service manual http://www.servicematters.com/maytag...s/16010312.pdf I think I would trust the wiring diagram included with the parts over the service manual. Unfortunately the diagram is not very legible and I could not find a better copy. The 20 amp breaker is for the microwave. I would check that you have the correct power to the unit. 240 volts from L1 to L2 120 volts from L1 and L2 to Neutral. It is unclear as to which side they use to power the control board. The diagram does show an High Limit Thermostat (Item 17 in the "Body" section). Usually though this just kills power to the elements but it is probably worth while checking that it has continuity.
__________________
| Display Modes | |
