Discuss
Error code
 in
Our lower element burnt in our maytag oven. we replaced it with proper element and element keeps heating. will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error code
  #1 (permalink)
Old 12-15-2012, 07:40 AM
Junior Member
joe yurchevich is on a distinguished road
Default Error code
Brand: Maytag   Age: 5 - 10 years
Our lower element burnt in our maytag oven. we replaced it with proper element and element keeps heating. will not reach temp and hold. later we got and F1 display on front display. HELP PLEASE
Ads By Google
  #2 (permalink)
Old 12-15-2012, 10:20 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Also I do not quite understand your post.
Usually if an element goes on and stays on as you said your's does, the oven will overheat.
Could you explain what is happening re: is it on full, is it cycling' does the broiler element ever come on etc.?
__________________
  #3 (permalink)
Old 12-15-2012, 11:02 AM
Junior Member
Default
hi
model no is WER5570ACW
serial no is 1780607BWY
The oven does overheat and the broiler element doesn't come on even when just broil is required
  #4 (permalink)
Old 12-15-2012, 12:26 PM
Senior Expert
APP Volunteer
Default
Sorry but I cannot find any info on the given model number.
Tried AppliancePartsPros and the Maytag site
All that comes up with WER without and numbers is a couple dryers.
Please check the model number.
Also if this is a non USA model odds are I will not be able to find info.
I did look up F1 for Maytag but there are a bunch of them depending on the unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven Error Code F3 E2 - Replaced Oven Tem Sensor and still getting error loanguy7171973 Oven Repair (including Ranges and Cooktops) 1 12-01-2012 03:53 AM
ERROR CODE F6E5 Cancel key error tammike Oven Repair (including Ranges and Cooktops) 8 08-06-2012 08:54 AM
Duet error code FH and diagnostic code C03 angelo78 Washer Repair 0 03-21-2012 08:12 AM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
