| » Is this the right part for my stove! |
Model Number: # SF385PEGB 6 Brand: Whirlpool Age: 5 - 10 years
Hello again!
I would really appreciate a response. Thanks! Problem: My oven will not work. Stovetop burners work fine however. Typical attempts to pre-heat/turn on oven trigger only the "clicking" sound, but no ignition. No heat, no gas emissions either. Before purchase, I'd like to ensure I need replacement part: "Oven bake burner with spark igniter" (Part #: AP3598752) and not any other. Photo Reference: http://www.appliancepartspros.com/pa...598752&image=0 My Stove is a Whirlpool Super Capacity 465 Accubake System. Model # SF385PEGB 6 Thanks in advance for a timely response! Rick Ads By Google Related Models |
Quote:
You may want to check this part first. If the coils are bad in the valve it won't allow gas to flow. Orange is the common, red is the bake, and blue is the broil. I believe you should read somewhere around 230 ohms between the common and red and common and blue. Also believe the voltage between common and each of the others when the oven function is on should read around 14 vdc. Someone else out there may want to check my numbers. Part number: AP3866825
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| PArt # substitution for a Frigidaire glass top stove | johnnyjellybean | Oven Repair (including Ranges and Cooktops) | 5 | 05-13-2010 04:56 PM |
| Center, round metal part of Jenn-Air stove top eye broke | Dolliver | Oven Repair (including Ranges and Cooktops) | 0 | 08-08-2009 10:21 AM |
| Need discontinued part for Jenn-Air range. Part #74002173 Clock component | Sandi Gainey | Oven Repair (including Ranges and Cooktops) | 0 | 03-25-2009 05:33 PM |
| Amana stove burner head replacement part doesn't fit | smwatkins | Oven Repair (including Ranges and Cooktops) | 0 | 03-17-2009 12:54 PM |
| Roper Stove Top Range Part Recommendations | geekodude | Oven Repair (including Ranges and Cooktops) | 1 | 04-08-2008 02:34 PM |
