| » Whirlpool oven, F3E2 code |
Model Number: RF364PXPT0 Brand: Whirlpool Age: 5 - 10 years
Hi!!
Having a bit of trouble with my oven. For some reason, when you set the temperature, the oven ignores the setting and just keeps heating up. A few days ago, I tried it and it got to about 600 degrees, and the F3 E2 code came up. I changed the sensor, and it still does the same. Is it same to assume that the control board is toast (pun intended, lol). Or is there something else that might be the cause? On a related note, what usually goes wrong with control boards? What is usually the biggest culprit with these bad boards? Figured I'd give it a try and see what was wrong with it. I mean, if it is dead, no harm done Thanks! Ads By Google Related Models |
Parts for Whirlpool RF364PXPT0 Range - AppliancePartsPros.com See the attachment for the tech sheet Yes it sounds like the control board is toast. I am assuming that the control comes out of preheat (comes ready) but just keeps heating up. Hard to say what is wrong with the control board. Manufacturers do not publish schematics of the boards so it makes it difficult to troubleshoot. Take a look at the elements as it heats up. If one of the elements comes on and stays on then that is the probable cause. The elements should cycle back and forth in preheat and bake cycles. Could be that the electronics for that relay are screwed up and are keeping the relay closed all the time. Could also be that the relay's contacts are welded together so it is on whenever the DLB relay closes. If it is welded contacts you could try cleaning the contacts but this probably will not last too long. You could get the numbers off the relay and replace it thiough finding one may be a pain. Digikey does stock some of these relays.
__________________
- Last edited by denman : 12-13-2012 at 03:53 AM. |
| Display Modes | |
| New house, broken oven (F1E0 & F3E2) | dansanf11 | Oven Repair (including Ranges and Cooktops) | 0 | 12-05-2011 12:23 PM |
| Oven code F3E2 | Darren C | Oven Repair (including Ranges and Cooktops) | 1 | 10-19-2011 11:13 AM |
| Code F3E2 flashes after replacing oven heat sensor unit 2 times | lorrainebirkett | Oven Repair (including Ranges and Cooktops) | 0 | 09-07-2011 01:08 PM |
| F3e2 | CTomerlin | Oven Repair (including Ranges and Cooktops) | 1 | 08-28-2011 03:51 AM |
| whirlpool error code f3e2 | bakerbaker53 | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2008 12:46 PM |
