Discuss
Oven Temperature 25 degrees lower than display
 in
As tested with an oven thermometer, my oven is heating to 25 degrees below the display setting; e.g., if I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Temperature 25 degrees lower than display
  #1 (permalink)
Old 12-12-2012, 12:27 PM
Junior Member
geebekazoo is on a distinguished road
Default Oven Temperature 25 degrees lower than display
Model Number: SVE47500W   Brand: Jenn-Air   Age: More than 10 years
As tested with an oven thermometer, my oven is heating to 25 degrees below the display setting; e.g., if I set the oven for 450, the display eventually reads 450, but the actual oven temp is only 400.
Is there a way to test and/or adjust the thermostatic controls? Do I need a new temp sensor or is something else wrong? Please advise.
Related Models
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Amana SX1021.000 COMMERCIAL MICROWAVES
Amana SX1051.000 COMMERCIAL MICROWAVES
Amana SX19ML REF - SXS/I&W
Amana SX19MW REF - SXS/I&W
Amana SX19NL REF - SXS/I&W
Amana SX19NW REF - SXS/I&W
Amana SX22H REF - SXS/I&W
Amana SX22J REF - SXS/I&W
Amana SX22J Ref - SXS/I&W
Amana SX22MG REF - SXS/I&W
Amana SX22ML REF - SXS/I&W
  #2 (permalink)
Old 12-13-2012, 05:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Jenn-Air SVE47500W Range - AppliancePartsPros.com
Here is the operators manual. It shows how to calibrate the oven.
Your post is confusing you say that you are 25 degrees low but also say that a 450 setpoint gives a 400 actual which is 50 degrees.
Here is a good link on the oven sensor, check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric...air-topics.php
Check that both elements are OK.
Most units switch between bake and broil during preheat and also during bake.
If one element is not working then you will get a lang preheat.
Also during bake the temperature gradient/profile will not be consistent which may be why you get a low reading depending where you put the thermometer.
If it is a bad element be sure to unplug or switch off the breaker to the unit before replacing it.
On many units the elements have 120 volts on one side of the element even when it is switched off.
__________________
  #3 (permalink)
Old 12-13-2012, 08:04 AM
Junior Member
Default
denman, thanks for the reply and that good information. I mis-typed the "400", it should have read 425.
In terms of testing the oven temp, I placed the oven thermometer on the middle rack, where one would most commonly bake something. Then I set the oven temp, let the pre-heat cycle finish, waited an additional 10 minutes to insure that the oven temp stabilized, and then looked through the door glass to get a temp reading. Should I have done something differently?
  #4 (permalink)
Old 12-13-2012, 10:22 AM
Senior Expert
APP Volunteer
Default
No sounds like you did it correctly.
If both elements work then I would try the oven calibration.
Also looks like my link to the operators manual did not work so here is a second try
https://www.maytag.com/digitalassets...E47500B-UC.pdf
__________________
  #5 (permalink)
Old 12-13-2012, 02:56 PM
Junior Member
Default
Denman, thanks! After looking at that temperature adjustment procedure, I have one dumb question. Do I enter the temp differential as a + or a - ???
  #6 (permalink)
Old 12-13-2012, 05:28 PM
Senior Expert
APP Volunteer
Default
Sorry but I do not know, the procedure seems to miss this point.
I would try +10 first and see what happens.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven will not light 100 degrees in display BAD LS1 Oven Repair (including Ranges and Cooktops) 1 02-23-2009 06:53 AM
Oven temperature of 25 degrees carolr Oven Repair (including Ranges and Cooktops) 3 01-18-2009 08:44 AM
Temperature not where display says (at least 75-100 degrees below) SidCharming Oven Repair (including Ranges and Cooktops) 1 01-04-2009 06:48 PM
Oven temperature never gets above 199 degrees richappy Oven Repair (including Ranges and Cooktops) 0 11-01-2008 05:37 PM
oven temperature varies 100 degrees bigal_1234@msn.com Oven Repair (including Ranges and Cooktops) 2 01-31-2008 04:09 PM
