| » Jennair Cooktop Problem |
Model Number: CVEX4370 Brand: Jenn-Air Age: More than 10 years
Have two of the AR141 radiant burner cartridges. The front right burner is malfunctioning. When it is on low, it cycles on and off and will not hold a low temp. I switched the left and right cartridges to see if the problem was the burner or not, but the problem did not follow leading me to believe that the problem is in the knob control assembly. Is there any other troubleshooting? Is there a way to repair the knob assembly? Is it even replaceable?
Hello,
What are the ends of the cooktop and the cartridge model numbers? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Sounds like the problem is a bad infinite switch for this burner.
In order to access the part remove all knobs and the screws attaching the control panel to the control box. Once proper screws are removed, the control switch plate may be lifted from the control box. Before you remove the wires from the old infinite switch draw a picture so you will know how to connect them to the new switch. - The infinite switch Part number: 703650 Here are the breakdown diagrams and Parts for Jenn-Air CVEX4370B Cooktop - AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| One burner of a Jennair Cooktop doesn't spark | scooterdog | Oven Repair (including Ranges and Cooktops) | 0 | 07-14-2012 04:35 AM |
| jennair cooktop Jec0530 HELP HELP | IESHAE | Oven Repair (including Ranges and Cooktops) | 3 | 06-08-2012 01:28 PM |
| jennair cooktop with downdraft | melissam | Oven Repair (including Ranges and Cooktops) | 0 | 01-28-2012 11:02 AM |
| Jennair cooktop fan switch | sb1357 | Oven Repair (including Ranges and Cooktops) | 1 | 10-25-2010 10:29 AM |
| jennair cooktop | lpisansky | Oven Repair (including Ranges and Cooktops) | 10 | 08-23-2009 10:07 AM |
