Discuss
oven light problem after thermal fuse repair
 in
Just replaced both thermal fuses after self clean function caused them to blow. But now the lights don't work. When
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven light problem after thermal fuse repair
  #1 (permalink)
Old 12-09-2012, 09:45 AM
Junior Member
scalawagy is on a distinguished road
Default oven light problem after thermal fuse repair
Model Number: KEBC208KWH04   Brand: Kitchen Aid   Age: 1 - 5 years
When I hit the light switch on the touch pad it beeps three times, I don't remember it doing this before.
I've checked the bulbs for continuity, they are good.
I've checked for loose wire behind control panel, nothing obvious.
I see the light power supply transformer on then diagram, but I'm not sure where it is.
Is it on the board or somewhere else?
Could it have been damaged during the self cleaning overheat?
What else should I check?
I haven't checked for loose wire at back of unit, I don't recall any other wire connections back there. Should I pull the unit again and look back there?
Thanks for any help
Ken
Ads By Google
Related Models
Whirlpool KEBC208KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC247KBL0 OVEN
Whirlpool KEBC247KBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH0 OVEN
Whirlpool KEBC247KWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247VBL00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC247VSS00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VSS02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC276KBL0 OVEN
Whirlpool KEBC276KBL02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KBL1 DOUBLE OVEN
Whirlpool KEBC276KSS03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH0 OVEN
Whirlpool KEBC276KWH02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH1 DOUBLE OVEN
Whirlpool KEBC277KBL0 OVEN
Whirlpool KEBC277KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBL1 DOUBLE OVEN
Whirlpool KEBC277KBT0 OVEN
Whirlpool KEBC277KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBT1 DOUBLE OVEN
Whirlpool KEBC277KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH0 OVEN
Whirlpool KEBC277KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH1 DOUBLE OVEN
Whirlpool KEBC278HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBL1 OVEN
Whirlpool KEBC278HBL2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBL3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBT1 OVEN
Whirlpool KEBC278HBT2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HWH1 OVEN
Whirlpool KEBC278HWH2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278KBL0 OVEN
Whirlpool KEBC278KBL02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL2 ELECTRIC RANGE
Whirlpool KEBI100VBL3 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100WWH0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL0 ELEC. BUILT-IN OVEN
Whirlpool KEBI100YBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL3 30" ELEC BUILT-IN OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool thermal fuse problem - Service Pointer K4317445 Taoiseach Oven Repair (including Ranges and Cooktops) 0 11-16-2011 12:56 PM
Kitchen Aid Thermal fuse problem Gilbert K Dishwasher Repair 0 07-06-2011 03:48 PM
Whirlpool Dishwasher Thermal Fuse Problem Chip'n Alvin Dishwasher Repair 3 07-06-2011 12:17 AM
problem replacing thermal fuse in wall oven Tosha1 Oven Repair (including Ranges and Cooktops) 1 06-18-2009 08:58 PM
Persistent Thermal Fuse Problem Davejb Dishwasher Repair 2 07-25-2008 08:00 AM
