| » safety valve |
Model Number: fgf337bcb Brand: Frigidaire Age: 5 - 10 years
I could use a little help. My oven lights after a very long time - sometimes 30 minutes. From what I understand, My ignitghter is working, because I can see it glowing(fairly brightly), but I never tested it with a volt meter. All the burners on top work with out any problems. When the oven is not lighting, I do not hear or smell any gas. I am assuming that my problem is a faulty safety valve not letting the gas thru. Although, every once in a while the oven works fine without any problems. I don't think it's a thermostat or a contronl panel problem,( because once light the oven works ok) but I could be wrong. Does this problem sound like a faulty safety valve?, and is a faulty safety valve a common problem? Thank you.
Anthony |
Safety valves do go bad sometimes but not often,for example in the last five years i have change maybe two safety valves,this condition you have sound like a ignitor going bad, taking a long time to light is common when ignitor's are weak.
| Display Modes | |
| washing machine is tripping the safety switch on my circuit board | olwyn | Washer Repair | 0 | 01-19-2008 09:39 PM |
| Ice maker Valve | normdyer | Refrigerator & Freezer Repair | 2 | 01-12-2008 02:33 PM |
| Need Safety valve for Gaffers and Sattler oven | xuuly | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2007 02:59 PM |
| Safety Thermosta | steve_a_mann | Oven Repair (including Ranges and Cooktops) | 0 | 09-30-2007 04:48 PM |
| Ge inlet valve | Mark | Dishwasher Repair | 1 | 07-20-2007 07:22 PM |
