Discuss
GE Washer not spinning or agitating
 in
GE Washer Model# WJSR4160G1WW Fills and drains fine, timer advances, lid switch has continuity, fuse has continuity. Belt is on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Washer not spinning or agitating
  #1 (permalink)
Old 12-05-2012, 01:57 PM
Junior Member
dp2763 is on a distinguished road
Default GE Washer not spinning or agitating
Model Number: WJSR4160G1WW   Brand: GE   Age: 5 - 10 years
Fills and drains fine, timer advances, lid switch has continuity, fuse has continuity. Belt is on but is in bad shape. Motor does not run....shaft turns freely by hand.
I took belt off and tried to run it, but it did not turn.
Motor is a WH01X10057 that has a flashing light. it flashes twice and pauses before flashing twice again. The sheet says that is a belt slipping code. However the motot does not turn with the belt off either. Sheet also says that if components check fine, then replace motor.
Motor is very expensive....so I want to run it past you all before I take the plunge and buy one from you.
Related Models
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
General Electric WKSE6280B2WW Washer
General Electric WKSE6280B3WW Washer
General Electric WKSR2100T2AA Washer
General Electric WKSR2100T2WW Washer
General Electric WKSR2100T3AA Washer
General Electric WKSR2100T3WW Washer
General Electric WKSR2100T5AA Washer
General Electric WKSR2100T5WW Washer
General Electric WKSR2100T6AA Washer
General Electric WKSR2100T6WW Washer
General Electric WKSR2100T8AA Washer
General Electric WKSR2100T8WW Washer
General Electric WKSR2100T9AA Washer
General Electric WKSR2100T9WW Washer
General Electric WKSR2100TAAA Washer
General Electric WKSR2100TAWW Washer
General Electric WKSR2100TBAA Washer
General Electric WKSR2100TBWW Washer
General Electric WKSR2100TCAA Washer
General Electric WKSR2100TCWW Washer
Amana WKU-617 RANGE- S/C S/I DDRAFT GAS
Amana WKU-617A RANGE- S/C S/I DDRAFT GAS
General Electric WKXR2100T2AA Washer
General Electric WKXR2100T2WW Washer
General Electric WKXR2100T3AA Washer
General Electric WKXR2100T3WW Washer
General Electric WKXR2100T5AA Washer
General Electric WKXR2100T5WW Washer
General Electric WKXR2100T6AA Washer
General Electric WKXR2100T6WW Washer
General Electric WKXR2100T8AA Washer
General Electric WKXR2100T8WW Washer
General Electric WKXR2100TAAA Washer
General Electric WKXR2100TAWW Washer
General Electric WKXR2100TBAA Washer
General Electric WKXR2100TBWW Washer
Frigidaire WL24F2WWMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WWMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F2WYMC Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WWMA Gib(v1) / Laundry Center
Frigidaire WL24F4WWMB Gib(v1) / Laundry Center
Frigidaire WL24F4WYMA Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WYMB Gib(v1) / 24 " Laundry Center
Frigidaire WL24F4WYMC Gib(v1) / 24 " Laundry Center
General Electric WLCD1030Y0AC Washer
General Electric WLCD1030Y0WC Washer
General Electric WLCD1030Y2AC Washer
General Electric WLCD1030Y2WC Washer
General Electric WLCD2050B0KC Washer
General Electric WLCD2050B0WC Washer
General Electric WLCD2050B1WC Washer
General Electric WLCD2050D0WC Washer
General Electric WLCD2050Y0AC Washer
General Electric WLCD2050Y0WC Washer
General Electric WLDSR416F0WC Washer
General Electric WLDSR416F1WC Washer
General Electric WLDSR416F2W WASHER
General Electric WLDSR416F2WC WASHER
General Electric WLDSR416F3WC WASHER
Whirlpool WLE30300 30" Electric Freestanding Standard Clean
Whirlpool WLE32300 30"Electric Range Coil Cooktop E-Z Clean Oven
Whirlpool WLE34200 30" Electric Range E-Z Clean Oven
Whirlpool WLE34300 30" Electric Range E-Z Clean Oven
Whirlpool WLE34400 30" Electric Range E-Z Clean Oven
General Electric WLE4000B1WW Washer
General Electric WLE4000B2WW Washer
General Electric WLE4000B3WW Washer
General Electric WLE6000B1WW Washer
General Electric WLE6000B2WW Washer
General Electric WLE6000B3WW Washer
General Electric WLE6500B1WW Washer
General Electric WLE6500B2WW Washer
General Electric WLE6500B3WW Washer
Whirlpool WLE83300 30" ELECTRIC RANGE CERAN COOKTOP
Whirlpool WLE83310 30" ELECTRIC RANGE CERAN COOKTOP
White Westinghouse WLF303PHDB White Westinghouse/gas Range
White Westinghouse WLF303PHDC White Westinghouse/gas Range
White Westinghouse WLF303PHWB White Westinghouse/gas Range
White Westinghouse WLF303PHWC White Westinghouse/gas Range
White Westinghouse WLF311SHDA White Westinghouse/gas Range
White Westinghouse WLF311SHDB White Westinghouse/gas Range
White Westinghouse WLF311SHWA White Westinghouse/gas Range
White Westinghouse WLF311SHWB White Westinghouse/gas Range
Whirlpool WLP30800 30" Electric Range Coil Cooktop
Whirlpool WLP32200 30" Electric Range Self Clean Oven
Whirlpool WLP32800 30" Electric Range Self Clean Oven
Whirlpool WLP32810 30" Electric Range Self Clean Oven
Whirlpool WLP34200 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer not agitating or spinning help please oxtart Washer Repair 14 09-17-2012 05:25 PM
Washer not spinning or agitating drslgsr Washer Repair 1 05-30-2011 05:03 PM
Washer not spinning or agitating jramirez1021 Washer Repair 1 01-31-2011 09:23 AM
washer not spinning or agitating but does everything else albarran61483 Washer Repair 5 03-29-2010 06:22 AM
washer not spinning or agitating again. bounette77 Washer Repair 2 02-17-2010 11:00 AM
