Discuss
smooth top cooktop-burners not heating
 in
I have a Thermador C30-01 smooth top cooktop. One burner had not been heating up at all, for awhile. Now
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » smooth top cooktop-burners not heating
  #1 (permalink)
Old 12-03-2012, 06:18 PM
Junior Member
davidjames is on a distinguished road
Default smooth top cooktop-burners not heating
Model Number: C30-01   Brand: Thermador   Age: More than 10 years
I have a Thermador C30-01 smooth top cooktop. One burner had not been heating up at all, for awhile. Now the other 3 burners just quit and does not heat up at all. When I turn the 4 knobs on, all the red light comes on below the knobs, and the power is on.
Does anyone have any suggestions as to what the problem is?
Thank you.
Ads By Google
Related Models
Jenn-Air C300 Surface Unit - Ddraft Ele
Hoover C3003--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3003055 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005001 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005100 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007001 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007071 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007100 Coml - Access,burnisher,floor Mch,wet/dry
Jenn-Air C301 Surface Unit - Ddraft Ele
Jenn-Air C301-C Surface Unit - Ddraft Ele
Thermador C301U
Jenn-Air C302 Surface Unit - Ddraft Ele
Thermador C302U
Whirlpool C3057X0
Whirlpool C3057^0
Jenn-Air C306 Surface Unit - Ddraft Ele
Jenn-Air C306-C Surface Unit - Ddraft Ele
Hoover C3077
Crosley C31000PAA Range - F/s Std Gas
Crosley C31000PAAD Range - F/s Std Gas
Crosley C31000PAT Range - F/s Std Gas
Crosley C31000PATP Range - F/s Std Gas
Crosley C31000PAW Range - F/s Std Gas
Crosley C31000PAWD Range - F/s Std Gas
Crosley C31000PAWP Range - F/s Std Gas
Crosley C31100PAA Range - F/s Std Gas
Crosley C31100PAV Range - F/s Std Gas
Crosley C31100SAA Range - F/s Std Gas
Crosley C31100SAAP Range - F/s Std Gas
Crosley C31100SAT Range - F/s Std Gas
Crosley C31100SATP Range - F/s Std Gas
Crosley C31100SAW Range - F/s Std Gas
Crosley C31100SAWP Range - F/s Std Gas
Crosley C31103SAA Range - F/s Std Gas
Crosley C31103SAT Range - F/s Std Gas
Crosley C31103SAW Range - F/s Std Gas
Crosley C31113WAA Range - F/s Std Gas
Crosley C31113WAAP Range - F/s Std Gas
Crosley C31113WAB Range - F/s Std Gas
Crosley C31113WAT Range - F/s Std Gas
Crosley C31113WATP Range - F/s Std Gas
Crosley C31113WAV Range - F/s Std Gas
Crosley C31113WAVP Range - F/s Std Gas
Crosley C31113XAA Range - F/s Std Gas
Crosley C31113XAT Range - F/s Std Gas
Crosley C31113XAW Range - F/s Std Gas
Crosley C31315VAM Range - F/s Std Gas
Crosley C31315VAV Range - F/s Std Gas
Crosley C31315VBM Range - F/s Std Gas
Crosley C31315VBQ Range - F/s Std Gas
Crosley C31315VBV Range - F/s Std Gas
Crosley C31315XBT Range - F/s Std Gas
Crosley C31315XBW Range - F/s Std Gas
Whirlpool C3157W0
Whirlpool C3157^0
Jenn-Air C316 Surface Unit - Ddraft Ele
Jenn-Air C316-C Surface Unit - Ddraft Ele
Jenn-Air C316B Surface Unit - Ddraft Ele
Jenn-Air C316B-C Surface Unit - Ddraft Ele
Jenn-Air C316W Surface Unit - Ddraft Ele
Jenn-Air C316W-C Surface Unit - Ddraft Ele
Whirlpool C3257W0
Whirlpool C3257^0
Whirlpool C3357^0
Whirlpool C3408B0
Whirlpool C3408B1
Whirlpool C3408B2
Whirlpool C3457X0
Whirlpool C3457X1
Whirlpool C3457^0
Whirlpool C3457^1
Magic Chef C3510PVV Range - F/s Std Ele
Magic Chef C3521WRV Range - F/s Std Ele
Magic Chef C3521XRA Range - F/s Std Ele
Magic Chef C3521XRW Range - F/s Std Ele
Magic Chef C3523WVA Range - F/s Std Ele
Magic Chef C3523WVV Range - F/s Std Ele
Magic Chef C3542XRA Range - F/s Std Ele
Magic Chef C3542XRL Range - F/s Std Ele
Magic Chef C3542XRW Range - F/s Std Ele
Magic Chef C3581VRV Range - F/s Std Ele
Magic Chef C3581VUV Range - F/s Std Ele
Magic Chef C3581XRA Range - F/s Std Ele
Magic Chef C3581XRW Range - F/s Std Ele
Thermador C36
Hoover C3820--- Extr - W/fix & Rot Brush,tempest
Magic Chef C3842XRA Range - S/c F/s Ele
Magic Chef C3842XRL Range - S/c F/s Ele
Magic Chef C3842XRW Range - S/c F/s Ele
Magic Chef C3862VYV Range - S/c F/s Ele
Magic Chef C3862XYB Range - S/c F/s Ele
Magic Chef C3868VYV Range - S/c F/s Ele
Magic Chef C3882VRV Range - S/c F/s Ele
Magic Chef C3882VVV Range - S/c F/s Ele
Magic Chef C3882XRA Range - S/c F/s Ele
Magic Chef C3882XRB Range - S/c F/s Ele
Magic Chef C3882XRW Range - S/c F/s Ele
Magic Chef C3882XVA Range - S/c F/s Ele
Magic Chef C3882XVW Range - S/c F/s Ele
Magic Chef C3888VRV Range - S/c F/s Ele
Magic Chef C3888VVV Range - S/c F/s Ele
Magic Chef C3888XRA Range - S/c F/s Ele
Magic Chef C3888XRW Range - S/c F/s Ele
Magic Chef C3888XVA Range - S/c F/s Ele
Magic Chef C3888XVW Range - S/c F/s Ele
Hoover C4275--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C4277--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C4279--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5023--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5025--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5027--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5029--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5031--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5033--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5035--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5037--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5039--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5041--- Coml - Access,burnisher,floor Mch,wet/dry
  #2 (permalink)
Old 12-04-2012, 05:15 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
I cannot find any info on the given model number.
Since all 3 elements went out at the same time it sounds like a power problem. On many unit the lights use 120 volts but the elements require the full 240.
Could also be that a wire/connection has burned up or opened.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 12-04-2012, 02:41 PM
Junior Member
Default
Thanks for the info.
I checked the voltage on each hot wire, I am getting 120 at the plug. I took the cooktop apart, there are no loose connections or anything obvious like a burnt wire. There are many wires on each switch and on the ceramic burner assembly. I looked at the wire springs that make up the burners, I do not see any that are broken or burnt.
Is there a way to check if the switch is bad or the burners?
Thanks for your help.
  #4 (permalink)
Old 12-05-2012, 01:53 AM
Senior Expert
APP Volunteer
Default
You have to check for 240 volts between L1 and L2.
I am assuming you checked the voltage using ground/neutral as the reference.
This is no good as 120 volts from one side of the line can feed through parts in the oven so you see it on both sides.
__________________
  #5 (permalink)
Old 12-06-2012, 04:10 PM
Junior Member
Default
It's 240 volts, between L1 and L2
  #6 (permalink)
Old 12-07-2012, 12:20 AM
Senior Expert
APP Volunteer
Default
I cannot find any info on the given model number so must do some guessing.
It sounds like there is a bad connection/wire going to the elements.
All 3 elements or controls would not burn out at the same time.
Trace the L1 and L2 wires to the elements to see it there is a thermal cut-off in the circuit that would kill the power.
There is a possibility that there is a bad connection in the line that is a high resistance. When you measure the line with no load you will see the 240 volts but when an element starts to draw current all or most of the voltage is dropped across the bad connection.
You can check the elements with a meter using resistance.
Elements may range from 10 to 40 ohms approx.
Also each elemnt may have its own thermal cut-off built into the element.
It is wired in series with the element.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Smooth top burners are not getting on Kaila Oven Repair (including Ranges and Cooktops) 0 08-02-2011 08:48 AM
cooktop partial heating all burners boatjouster Oven Repair (including Ranges and Cooktops) 1 06-17-2011 06:16 PM
electric cooktop - 2 burners not heating sahsammer Oven Repair (including Ranges and Cooktops) 0 04-16-2010 08:25 PM
electric ceramic cooktop 2 left burners not heating sahsammer Oven Repair (including Ranges and Cooktops) 1 04-11-2010 09:51 AM
ceramic cooktop burners not heating sadie26677 Oven Repair (including Ranges and Cooktops) 0 01-24-2008 09:25 AM
