| » GE XL44 Oven lights, but flame is small. Wont reach Temp |
Model Number: JGBC17GER4WG Brand: GE Age: 5 - 10 years
I have a GE XL44 Gas Oven, model# Jgbc17ger4wg.
Range top works fine. Oven will not get to temperature. I have confirmed that the ignitor is fine. It drew 3.2 amps and dropped to 2.8 amps and kept glowing. I even changed it out to be sure. The flame lit on the burner, but what i noticed is the blue flames were only 1/4" long and did not spread on the deflector shield. What could be the problem.....valve, regulator or T-stat? How do I test these components to be sure? Ads By Google Related Models |
Hi.
Try to adjust the orifice on the top of the gas valve #214 on the diagram (Turn it CCW 1/2 turn) and also adjust the air/gas mixture #217 on the diagram Burner Assembly parts for GE JGBC17GER4 - AppliancePartsPros.com If that doesn't help and you already replaced the igniter then most likely it's bad safety gas valve. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Tappan oven lights but will not reach temp. | andy24u@centurylink.net | Oven Repair (including Ranges and Cooktops) | 0 | 08-10-2012 11:59 AM |
| GE XL44 Range Wont reach target temp | mdm6713@aol.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-15-2010 05:59 AM |
| Help!whirlpool oven wont reach temp | tabark | Oven Repair (including Ranges and Cooktops) | 0 | 12-08-2010 09:27 AM |
| Oven wont reach same temp as dial | yahshua | Oven Repair (including Ranges and Cooktops) | 0 | 06-08-2010 03:31 PM |
| Oven Lights but doesn't reach proper Temp | blottom | Oven Repair (including Ranges and Cooktops) | 0 | 10-20-2009 05:53 AM |
