| » Oven Light Quits when hot |
If the light is a standard 40 watt incandescent bulb, remove power/unplug the unit.
Remove the bulb and you will see a center contact in the receptacle. Many of these are a small tab, carefully bend this tab up. Be very gentle as you do not want to break it. Now give it a try. You could try replacing the bulb just to be sure it does not have an internal problem. Next would be to check the connectors going to the bulb receptacle. Next would be to replace the door switch. You did not include a model number so I do not know if the oven light is controller thru the control board but that is another possibility.
__________________
| Display Modes | |
| Oven (Bake) mode quits-goes to Broil | PET | Oven Repair (including Ranges and Cooktops) | 1 | 09-11-2012 11:13 AM |
| Gas Oven quits heating | garyp | Oven Repair (including Ranges and Cooktops) | 0 | 08-10-2011 08:37 PM |
| Oven quits when you touch the panel | srjacob | Oven Repair (including Ranges and Cooktops) | 0 | 05-13-2011 03:37 PM |
| oven beeps and quits working | orange1 | Oven Repair (including Ranges and Cooktops) | 1 | 09-27-2010 03:33 AM |
| Oven re-ignites occassionally, then quits completely | radac | Oven Repair (including Ranges and Cooktops) | 7 | 02-25-2008 11:18 AM |
