| » amana electric range oven not working |
Model Number: ACS7270AS Brand: Amana Age: 5 - 10 years
Used self clean cycle on oven and few days later replaced oven light. Oven functions won't work now. Tried replacing membrane panel and did no good. Clock functions work but no error code comes up. When you push any oven function button the panel goes dark. Do we need to replace the erc circuit board or something else wrong?
Parts for Amana ACS7270AS - AppliancePartsPros.com See the attachment for the tech sheet The ERC Control Module (item 22 in section 03 Main Top) would be at the top of the list. Does "any function" also include the oven light? There is a possibility that you have a bad connection in either power or Neutral wires going to the ERC. The bad connection allows enough power/amperage through to run the ERC electronics but drops the voltage when you try to close relays etc on the board. This would be a long shot but I would unplug the unit and check the wiring to the board.
__________________
| Display Modes | |
| Amana range burners/oven not working | DAMOFO | Oven Repair (including Ranges and Cooktops) | 4 | 06-27-2012 07:44 PM |
| Amana electric range (oven) wont heat up | flukekiller | Oven Repair (including Ranges and Cooktops) | 6 | 12-23-2011 06:01 AM |
| Electric range oven not working | lightnin | Oven Repair (including Ranges and Cooktops) | 1 | 06-25-2008 01:21 PM |
| Amana electric oven not working | marky mark | Oven Repair (including Ranges and Cooktops) | 1 | 06-10-2008 04:20 PM |
| electric range/oven clock not working | 50fbn | Oven Repair (including Ranges and Cooktops) | 1 | 07-20-2007 11:47 PM |
