Discuss
Oven not working after auto clean
 in
Last night I used the Self cleaning option on my Whirlpool oven and this morning discovered that neither the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not working after auto clean
  #1 (permalink)
Old 02-01-2008, 12:07 PM
lhensley lhensley is offline
Junior Member
lhensley is on a distinguished road
Default Oven not working after auto clean
Model Number: RBS305PDQ   Brand: Whirlpool   Age: 1 - 5 years
Last night I used the Self cleaning option on my Whirlpool oven and this morning discovered that neither the oven or broiler wouldn't heat. The display works fine and when you try to turn on the oven it displays and sounds like it is working but isn't. Any suggestions on what I need to do to try and fix this myself.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-01-2008, 12:20 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
have you tried unplugging stove for a minute +replugging +press cancel
__________________
  #3 (permalink)
Old 02-01-2008, 12:23 PM
fyxer fyxer is offline
Junior Member
fyxer is on a distinguished road
Default oven don't work after self cleaning
Self cleaning your oven calls for high temperature over 600 degrees and depending on how long you clean it for your element takes a beating, i think your element might be burnt out, this happens quite often,your oven is an electric,but on gas ovens the ignitor also burns out sometimes after self cleaning.
  #4 (permalink)
Old 02-04-2008, 07:24 PM
sharzaz sharzaz is offline
Junior Member
sharzaz is on a distinguished road
Default electric oven not working after clean mode
My frigidaire electric oven(3yrs old)is not working also after clean mode .Both element read about .13 ohms with wires disconnected.Also , when power on,switch on, tester probes on each end of element = no voltage. This condition for both top and bottom elements.Is there a in-line fuse ? Could this have burned out ? What does it look like ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Auto-Defrost not working? aimmer Refrigerator & Freezer Repair 1 01-10-2008 08:27 PM
Auto Moisture Sensing Plus not working mschmero Dryer Repair 2 01-06-2008 12:55 PM
Built in electric self clean oven Ladydi Oven Repair (including Ranges and Cooktops) 5 12-11-2007 01:25 PM
oven wont self clean jfisher915 Oven Repair (including Ranges and Cooktops) 1 12-03-2007 01:35 PM
Oven will not bake broil or clean feinerl Oven Repair (including Ranges and Cooktops) 5 10-24-2007 10:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
