Discuss
Oven won't heat after replacing thermal fuse
 in
The oven lost power after cleaning upper oven. From other posts got advice to replace thermal fuse. After replacing control
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't heat after replacing thermal fuse
  #1 (permalink)
Old 11-29-2012, 10:30 AM
Junior Member
bill cote is on a distinguished road
Default Oven won't heat after replacing thermal fuse
Model Number: kebs207dbl1   Brand: Kitchen Aid   Age: More than 10 years
The oven lost power after cleaning upper oven. From other posts got advice to replace thermal fuse. After replacing control panel thermal fuse, power was restored to both ovens and bottom oven will heat but no heat in upper oven. Ideas?
Ads By Google
Related Models
Whirlpool KEBS207DBL1
Whirlpool KEBS207DBL10
Whirlpool KEBS207DBL11
Whirlpool KEBS207DBL12
Whirlpool KEBS207DBL2
Whirlpool KEBS207DBL4
Whirlpool KEBS207DBL6
Whirlpool KEBS207DBL7
Whirlpool KEBS207DBL8
Whirlpool KEBS207DBL9
Whirlpool KEBS207DBT10
Whirlpool KEBS207DBT11
Whirlpool KEBS207DBT12
Whirlpool KEBS207DBT6
Whirlpool KEBS207DBT7
Whirlpool KEBS207DBT8
Whirlpool KEBS207DBT9
Whirlpool KEBS207DWH1
Whirlpool KEBS207DWH10
Whirlpool KEBS207DWH11
Whirlpool KEBS207DWH12
Whirlpool KEBS207DWH2
Whirlpool KEBS207DWH4
Whirlpool KEBS207DWH6
Whirlpool KEBS207DWH7
Whirlpool KEBS207DWH8
Whirlpool KEBS207DWH9
Whirlpool KEBS207SBL00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS207SSS00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS207SWH00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS207YAL0
Whirlpool KEBS207YAL1
Whirlpool KEBS207YAL2
Whirlpool KEBS207YAL3
Whirlpool KEBS207YBL0
Whirlpool KEBS207YBL1
Whirlpool KEBS207YBL2
Whirlpool KEBS207YBL3
Whirlpool KEBS207YWH0
Whirlpool KEBS207YWH1
Whirlpool KEBS207YWH2
Whirlpool KEBS207YWH3
Whirlpool KEBS208AAL0
Whirlpool KEBS208AAL1
Whirlpool KEBS208ABL0
Whirlpool KEBS208ABL1
Whirlpool KEBS208AWH0
Whirlpool KEBS208AWH1
Whirlpool KEBS208BAL0
Whirlpool KEBS208BAL1
Whirlpool KEBS208BAL2
Whirlpool KEBS208BBL0
Whirlpool KEBS208BBL1
Whirlpool KEBS208BBL2
Whirlpool KEBS208BWH0
Whirlpool KEBS208BWH1
Whirlpool KEBS208BWH2
Whirlpool KEBS208DBL1
Whirlpool KEBS208DBL10
Whirlpool KEBS208DBL11
Whirlpool KEBS208DBL2
Whirlpool KEBS208DBL4
Whirlpool KEBS208DBL6
Whirlpool KEBS208DBL7
Whirlpool KEBS208DBL8
Whirlpool KEBS208DBL9
Whirlpool KEBS208DBS10
Whirlpool KEBS208DBS11
Whirlpool KEBS208DBS6
Whirlpool KEBS208DBS7
Whirlpool KEBS208DBS8
Whirlpool KEBS208DBS9
Whirlpool KEBS208DSS10
Whirlpool KEBS208DSS11
Whirlpool KEBS208DSS6
Whirlpool KEBS208DSS7
Whirlpool KEBS208DSS8
Whirlpool KEBS208DSS9
Whirlpool KEBS208DWH1
Whirlpool KEBS208DWH10
Whirlpool KEBS208DWH11
Whirlpool KEBS208DWH2
Whirlpool KEBS208DWH4
Whirlpool KEBS208DWH6
Whirlpool KEBS208DWH7
Whirlpool KEBS208DWH8
Whirlpool KEBS208DWH9
Whirlpool KEBS208SBL00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS208SBT00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS208SSS00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS208SWH00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS245SBL0
Whirlpool KEBS245SBL1
Whirlpool KEBS246BBL0
Whirlpool KEBS246BBL1
Whirlpool KEBS246BBL2
Whirlpool KEBS246BBL3
Whirlpool KEBS246BWH0
Whirlpool KEBS246BWH1
Whirlpool KEBS246BWH2
Whirlpool KEBS246BWH3
Whirlpool KEBS246SBL1
Whirlpool KEBS246SBL2
Whirlpool KEBS246WBL0
Whirlpool KEBS246WBL1
Whirlpool KEBS246WBL2
Whirlpool KEBS246WBL3
Whirlpool KEBS246XBL0
Whirlpool KEBS246XBL2
Whirlpool KEBS246XBL3
Whirlpool KEBS246YBL0
Whirlpool KEBS246YBL1
Whirlpool KEBS246YBL2
Whirlpool KEBS246YBL3
Whirlpool KEBS246YBL4
Whirlpool KEBS246YWH0
Whirlpool KEBS246YWH1
Whirlpool KEBS246YWH3
Whirlpool KEBS246YWH4
Whirlpool KEBS247DBL1
  #2 (permalink)
Old 11-29-2012, 01:28 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool KEBS207DBL1 Wall Oven - AppliancePartsPros.com
See the attachment for the tech sheet
I am assuming that the oven stays in pre-heat and never comes ready.
You may also have blown the thermal fuse (item 37 in the Oven Parts section).
Would also be a good idea once you get it repaired to check the actual oven temperature with an oven thermometer at about 450 degrees. Just to be sure that the temperature is controlling the temperature correctly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing thermal fuse maedmurray@gmail.com Dryer Repair 0 10-09-2012 07:17 PM
Whirpool Electric Oven Wont Heat - Thermal Fuse Good Hunt9876 Oven Repair (including Ranges and Cooktops) 0 08-23-2012 07:32 PM
Replacing thermal fuse and Ignitor Givehope2lives Dryer Repair 0 01-06-2010 11:19 AM
replacing thermal fuse miltrot Dryer Repair 1 07-09-2009 04:51 PM
problem replacing thermal fuse in wall oven Tosha1 Oven Repair (including Ranges and Cooktops) 1 06-18-2009 08:58 PM
